jose1711 Geschrieben November 21, 2013 at 07:58 Share Geschrieben November 21, 2013 at 07:58 hello, i'd like to ask.. is there a software way to turn off the bright blue led on master? thank you, jose Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben November 21, 2013 at 08:07 Share Geschrieben November 21, 2013 at 08:07 There is no API to do that. It would be possible to turn it of by changing and recompiling the firmware. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Stefan Geschrieben November 21, 2013 at 09:46 Share Geschrieben November 21, 2013 at 09:46 In the bricklib/utility/init.c you must comment the both lines led_on(LED_STD_BLUE); led_tick_task(tick_type); out. After compiling and flashing this new firmware, the blue led will be disabled. Firmware compiling tutorial: http://www.tinkerforge.com/en/doc/Software/Firmwares_And_Plugins.html#firmwares-and-plugins Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Cathodion Geschrieben November 22, 2013 at 12:32 Share Geschrieben November 22, 2013 at 12:32 In the bricklib/utility/init.c you must comment the both lines led_on(LED_STD_BLUE); led_tick_task(tick_type); out. After compiling and flashing this new firmware, the blue led will be disabled. Firmware compiling tutorial: http://www.tinkerforge.com/en/doc/Software/Firmwares_And_Plugins.html#firmwares-and-plugins Behold the power of Open Source. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Stefan Geschrieben June 13, 2015 at 14:47 Share Geschrieben June 13, 2015 at 14:47 There is an API to disable the status led since Master Brick firmware 2.3.2. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
