Jon Geschrieben November 3, 2015 at 10:36 Share Geschrieben November 3, 2015 at 10:36 Hi, I'm trying to run "matlab_example_callback.m" for BrickletVoltageCurrent. When the example code "set(vc, 'PowerReachedCallback', @(h, e) cb_power_reached(e));" is executed MATLAB reports the following error: java.lang.NullPointerException at com.mathworks.jmi.bean.MatlabBeanInterface.addCallback(MatlabBeanInterface.java:484) at com.mathworks.jmi.bean.MatlabCallbackInterface.addCallback(MatlabCallbackInterface.java:130) If I type set(vc) there is no callback class listed to register... Class: [1x1 java.lang.Class] Configuration: [1x1 com.tinkerforge.BrickletVoltageCurrent$Configuration] Current: 0 CurrentCallbackPeriod: 1000 CurrentCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$CurrentCallbackThreshold] DebouncePeriod: 100 Identity: [1x1 com.tinkerforge.Device$Identity] Power: 0 PowerCallbackPeriod: 0 PowerCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$PowerCallbackThreshold] Voltage: 0 VoltageCallbackPeriod: 0 VoltageCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$VoltageCallbackThreshold] The example callback won't register. Does anyone have any ideas what could be wrong here? Many thanks Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben November 4, 2015 at 16:59 Share Geschrieben November 4, 2015 at 16:59 I tested with this function matlab_example_threshold() import com.tinkerforge.IPConnection; import com.tinkerforge.BrickletVoltageCurrent; ipcon = IPConnection(); % Create IP connection vc = BrickletVoltageCurrent('XYZ', ipcon); % Create device object set(vc) end and got this output >> matlab_example_threshold APIVersion Class Configuration Current CurrentCallbackPeriod CurrentCallbackThreshold DebouncePeriod Identity Power PowerCallbackPeriod PowerCallbackThreshold ResponseExpectedAll: [ on | off ] Voltage VoltageCallbackPeriod VoltageCallbackThreshold PowerReachedCallback: string -or- function handle -or- cell array VoltageReachedCallback: string -or- function handle -or- cell array VoltageCallback: string -or- function handle -or- cell array CurrentReachedCallback: string -or- function handle -or- cell array CurrentCallback: string -or- function handle -or- cell array PowerCallback: string -or- function handle -or- cell array ButtonDownFcn: string -or- function handle -or- cell array Children Clipping: [ {on} | off ] CreateFcn: string -or- function handle -or- cell array DeleteFcn: string -or- function handle -or- cell array BusyAction: [ {queue} | cancel ] HandleVisibility: [ {on} | callback | off ] HitTest: [ {on} | off ] Interruptible: [ {on} | off ] Parent Selected: [ on | off ] SelectionHighlight: [ {on} | off ] Tag UIContextMenu UserData Visible: [ {on} | off ] Did you install the bindings according to the documentation? http://www.tinkerforge.com/en/doc/Software/API_Bindings_MATLAB.html#matlab Also make sure to use the Tinkerforge.jar from the MATLAB bindings zip file. The Tinkerforge.jar from the Java bindings will probably not work. What MATLAB version are you using? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Jon Geschrieben November 9, 2015 at 00:46 Autor Share Geschrieben November 9, 2015 at 00:46 Hi photron Thank you for responding. Something strange is happening for me. I am using MATLAB 2015b and the Tinkerforge.jar file from the \MATLAB bindings directory (v2_0_5 file size: 980,064 bytes). In the MATLAB classpath.txt file I have this # DO NOT MODIFY THIS FILE. IT IS AN AUTOGENERATED FILE. $<Lots of MATLAB Jar files added to the path> $matlabroot/Tinkerforge.jar If I execute your simple code I get this: import com.tinkerforge.IPConnection; import com.tinkerforge.BrickletVoltageCurrent; ipcon = IPConnection(); % Create IP connection vc = BrickletVoltageCurrent(UID, ipcon); % Create device object >> set(vc) ans = CurrentCallbackPeriod: {} DebouncePeriod: {} PowerCallbackPeriod: {} ResponseExpectedAll: {} VoltageCallbackPeriod: {} >> ipcon.connect(HOST, PORT); % Can't use get without executing this >> get(vc) APIVersion: [3x1 int16] Class: [1x1 java.lang.Class] Configuration: [1x1 com.tinkerforge.BrickletVoltageCurrent$Configuration] Current: 0 CurrentCallbackPeriod: 10 CurrentCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$CurrentCallbackThreshold] DebouncePeriod: 100 Identity: [1x1 com.tinkerforge.Device$Identity] Power: 0 PowerCallbackPeriod: 0 PowerCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$PowerCallbackThreshold] Voltage: 0 VoltageCallbackPeriod: 0 VoltageCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$VoltageCallbackThreshold] >> ver ver ---------------------------------------------------------------------------------------------------- MATLAB Version: 8.6.0.232648 (R2015b) MATLAB License Number: xxxxxx Operating System: Microsoft Windows 8.1 Version 6.3 (Build 9600) Java Version: Java 1.7.0_60-b19 with Oracle Corporation Java HotSpot(TM) 64-Bit Server VM mixed mode ---------------------------------------------------------------------------------------------------- MATLAB Version 8.6 (R2015b Prerelease) Signal Processing Toolbox Version 7.1 (R2015b Prerelease) Please can I ask what version of MATLAB you are using? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben November 9, 2015 at 09:13 Share Geschrieben November 9, 2015 at 09:13 I tested with R2012a. I think I found the problem. There's a change about how callbacks are handled in R2014a, see http://undocumentedmatlab.com/blog/matlab-callbacks-for-java-events-in-r2014a According to that blog post you need to replace vc = BrickletVoltageCurrent(UID, ipcon); with vc = handle(BrickletVoltageCurrent(UID, ipcon), 'CallbackProperties'); to expose callbacks again. Could you test that? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Jon Geschrieben November 9, 2015 at 17:09 Autor Share Geschrieben November 9, 2015 at 17:09 Fantastic Photron - problem solved, Tinkerforge Callbacks are now established in MATLAB R2015b - Don't you just love undocumented features. For completeness the following updated code now produces this output. import com.tinkerforge.IPConnection; import com.tinkerforge.BrickletVoltageCurrent; ipcon = IPConnection(); % Create IP connection vc = handle(BrickletVoltageCurrent(UID, ipcon),'CallbackProperties'); >> set(vc) ans = CurrentCallbackPeriod: {} DebouncePeriod: {} PowerCallbackPeriod: {} ResponseExpectedAll: {} VoltageCallbackPeriod: {} PowerReachedCallback: {} VoltageReachedCallback: {} VoltageCallback: {} CurrentReachedCallback: {} CurrentCallback: {} PowerCallback: {} My understanding is the listeners only report when a change is detected which means I can't check if the callback is actually executing until tomorrow when I can add a test load. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
