potato101 Geschrieben August 17, 2016 at 14:29 Share Geschrieben August 17, 2016 at 14:29 Hi, I made an application with GAMBAS which can control a meeting room schedule and I wanted to upload it to my HDMI Display (12.7cm) from TinkerForge. I guess we can say that I'm a beginner with TinkerForge and I'm not able to send my application to the screen. My HDMI display is connected to a RED Brick. I can turn on the screen without any problems, I can also access all the RED Brick OS with the SD card. Basically, the screen works perfectly. I tried connecting the RED brick to the Internet but the WiFi Extension is not compatible with the RED Brick. So I wanted to know if there's any way that I can upload my application via USB to the RED brick, or the SD card that's in the RED Brick slot. Let me know if you have anymore questions. Thanks for your help! Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben August 17, 2016 at 20:40 Share Geschrieben August 17, 2016 at 20:40 You can upload via USB through the program tab in Brick Viewer, see here: http://www.tinkerforge.com/en/doc/Hardware/Bricks/RED_Brick_Program_Tab.html#red-brick-program-tab For WIFI we recommend a USB WIFI Stick, like this one: https://www.tinkerforge.com/en/shop/accessories/red-brick/wifi-usb-adapter.html Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
potato101 Geschrieben August 18, 2016 at 12:13 Autor Share Geschrieben August 18, 2016 at 12:13 Perfect, thanks for your help! Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
