BOBmoraine Geschrieben January 22, 2016 at 04:44 Share Geschrieben January 22, 2016 at 04:44 Moin, ich wollte bei meinem RED mit OpenHAB noch das addon "rrd4j" nachinstallieren, doch ich kann nichtmal ein fehlerfreies "apt-get upgrade" machen, folgend die Ausgaben: tf@TF_RED:~$ sudo apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these. The following packages have unmet dependencies: perl : Depends: perl-base (= 5.20.2-3+deb8u1) but 5.20.2-3+deb8u2 is installed Recommends: rename but it is not installed E: Unmet dependencies. Try using -f. tf@TF_RED:~$ sudo apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following extra packages will be installed: perl perl-modules Suggested packages: libb-lint-perl libcpanplus-dist-build-perl libcpanplus-perl libfile-checktree-perl liblog-message-simple-perl liblog-message-perl libobject-accessor-perl Recommended packages: rename libarchive-extract-perl libmodule-pluggable-perl libpod-latex-perl libterm-ui-perl libtext-soundex-perl libcgi-pm-perl libpackage-constants-perl The following packages will be upgraded: perl perl-modules 2 upgraded, 0 newly installed, 0 to remove and 274 not upgraded. 6 not fully installed or removed. Need to get 0 B/4,622 kB of archives. After this operation, 501 kB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 143407 files and directories currently installed.) Preparing to unpack .../perl_5.20.2-3+deb8u2_armhf.deb ... Unpacking perl (5.20.2-3+deb8u2) over (5.20.2-3+deb8u1) ... dpkg: error processing archive /var/cache/apt/archives/perl_5.20.2-3+deb8u2_armhf.deb (--unpack): trying to overwrite '/usr/bin/perldoc', which is also in package perl-doc 5.20.2-3+deb8u1 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Processing triggers for man-db (2.7.0.2-5) ... Errors were encountered while processing: /var/cache/apt/archives/perl_5.20.2-3+deb8u2_armhf.deb E: Sub-process /usr/bin/dpkg returned an error code (1) Ich habe leider nicht so die Linuxkenntnisse, daher wollte ich fragen ob mir jemand helfen kann das zu "reparieren". Die Linux-Version ist die vom "red_image_1_7_full.img". Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
m0d Geschrieben January 22, 2016 at 08:47 Share Geschrieben January 22, 2016 at 08:47 Schau mal hier: http://www.tinkerunity.org/forum/index.php/topic,3174.msg19663.html Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
BOBmoraine Geschrieben January 22, 2016 at 17:41 Autor Share Geschrieben January 22, 2016 at 17:41 Danke, das wars! Hier nochmal der Quote: Da steht sich das perl Package mit einigen anderen Packages auf den Füssen. Ich denke, dass ist ein Bug im perl Package selbst. In dieser Situation verweigert apt-get die Arbeit, weil es erst diese Problem beseitigt haben will. Ich konnte das Problem reproduzieren und so auflösen: sudo dpkg --purge cpanminus sudo dpkg --purge liblocal-lib-perl sudo dpkg --purge libmodule-build-perl sudo dpkg --purge libjson-pp-perl sudo dpkg --purge perl-doc sudo apt-get -f install sudo apt-get upgrade Jetzt stehen sich systemd und systemd-shim im Weg: sudo dpkg --purge systemd-shim sudo apt-get -f install sudo apt-get install systemd-shim sudo apt-get upgrade Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
