openHAB io16 Bricklet Test
rwblinn
connected a LED to A0 of the IO16 bricklet. Using the Brick Viewer and setting the Port Direction to Output, the LED can be turned on and off via changing the value Low to High vv.
Tried to setup the same by using openHAB, but the LED is not reacting.
Any hints what is worng in below openHAB Testconfiguration having Port A0 as output outa0?
#openhab.cfg
tinkerforge:hosts=127.0.0.1
tinkerforge:io16.uid=gkM
tinkerforge:io16.type=bricklet_io16
tinkerforge:io16.debouncePeriod=100
tinkerforge:io16outa0.uid=gkM
tinkerforge:io16outa0.subid=outa0
tinkerforge:io16outa0.type=io_actuator
tinkerforge:io16outa0.defaultState=true
#items
Number TF_AmbientLight "Luminance [%.0f lx]" { tinkerforge="uid=mdh" }
Switch outa0 "LED A0" { tinkerforge="uid=gkM, subid=outa0" }
#rules
import org.openhab.core.library.types.*
rule "LED Switch"
when
Item outa0 changed
then
if (outa0.state == true)
sendcommand(outa0, false)
else
sendcommand(outa0, true)
end
NOTE: Instead of true false also tried ON OFF.
#sitemap
sitemap tf_weather_station label="Weather Station"
Frame
Text item=TF_AmbientLight
Switch item=outa0
Link zu diesem Kommentar
Share on other sites
