Author Topic: IMU brick improvements needed  (Read 665 times)
stevehayles
  • Newbie
    • View Profile
« on: July 20, 2018, 12:09:37 »
One for the developers and hopefully not a difficult change.  The IMU v2 based on the Bosch BNO055 which has more 'sensor fusion modes' than we have options for.
In testing the unit I have found that the FMC (fast magnetometer calibration) is troublesome and makes yaw / compass / heading output very unrepeatable.
There is a fusion mode called 'NDOF_FMC_OFF' (0b00001011) which is the same as the BrickIMUV2.SENSOR_FUSION_ON mode but has the auto calibration routine for the magnetometer disabled.
You can still store a full calibration profile and all other functions are the same.  Using the same chip in an Arduino device has resulted in a more stable system without the unexplained 'jumps' in yaw output that are often seen in the NDOF mode
It looks like a simple enough change with no backward compatibility issues ?
Thanks for your consideration
borg
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: IMU brick improvements needed
« Reply #1 on: July 20, 2018, 15:26:58 »
Sounds useful to me, i will implement it.
borg
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
« Reply #2 on: July 20, 2018, 16:00:14 »
I just released IMU Brick V2 firmware 2.0.13 with the new parameter. Call set_sensor_fusion_mode with 3. The new constant will be available with the next Bindings release.
Changes:
https://github.com/Tinkerforge/imu-v2-brick/commit/cb5d24238a7e403ba1cb981c574e093d63176ebd
https://github.com/Tinkerforge/imu-v2-brick/commit/2d1e81f59339a4ea83eb09d3fe3dbc0a8b822366
https://github.com/Tinkerforge/generators/commit/f4f2a0d3b1660fb45aaf19d65b9bf1a51a7dfbe9
I tested with this small script and played around in Brick Viewer. I think i can see the difference between the two modes.
Code: [Select]
#!/usr/bin/env python
# -*- coding: utf-8 -*-
HOST = "localhost"
PORT = 4223
UID = "6xEivJ" # Change to your UID
from tinkerforge.brick_imu_v2 import BrickIMUV2
if __name__ == "__main__":
    imu = BrickIMUV2(UID, ipcon) # Create device object
    imu.set_sensor_fusion_mode(3)
    print(imu.get_sensor_fusion_mode())
stevehayles
  • Newbie
    • View Profile
« Reply #3 on: July 21, 2018, 14:27:24 »
Tested and working here.  Thank you for the amazingly fast response.
The BNO055 has some quirks around the magnetometer and compass / absolute yaw output.  My testing has shown the mode to be useful.
Thanks again
