Loetkolben Geschrieben July 26, 2018 at 22:37 Share Geschrieben July 26, 2018 at 22:37 Hallo zusammen, ein Debian Upgrade von 9.4 auf 9.5 am 26.7.2018 auf ein frisch aufgespieltes RED-Brick Image 1.12 war nicht erfolgreich. Anbei die Anleitung in welcher Reichenfolge man das Upgrade hinbekommt. Wuerde mich ueber ein Feedback freuen. Danke Der Loetkolben apt-get update # Debian von 9.4 auf 9.5 apt-get upgrade Downloading of Packages ... Preconfiguring packages ... (Reading database ... 204167 files and directories currently installed.) Preparing to unpack .../base-files_9.9+deb9u5_armhf.deb ... Unpacking base-files (9.9+deb9u5) over (9.9+deb9u4) ... Setting up base-files (9.9+deb9u5) ... Installing new version of config file /etc/debian_version ... (Reading database ... 204167 files and directories currently installed.) Preparing to unpack .../dpkg_1.18.25_armhf.deb ... Unpacking dpkg (1.18.25) over (1.18.24) ... Setting up dpkg (1.18.25) ... (Reading database ... 204167 files and directories currently installed.) Preparing to unpack .../libperl5.24_5.24.1-3+deb9u4_armhf.deb ... Unpacking libperl5.24:armhf (5.24.1-3+deb9u4) over (5.24.1-3+deb9u3) ... Preparing to unpack .../perl_5.24.1-3+deb9u4_armhf.deb ... Unpacking perl (5.24.1-3+deb9u4) over (5.24.1-3+deb9u3) ... dpkg: error processing archive /var/cache/apt/archives/perl_5.24.1-3+deb9u4_armhf.deb (--unpack): trying to overwrite '/usr/bin/perldoc', which is also in package perl-doc 5.24.1-3+deb9u3 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Preparing to unpack .../perl-base_5.24.1-3+deb9u4_armhf.deb ... Unpacking perl-base (5.24.1-3+deb9u4) over (5.24.1-3+deb9u3) ... Errors were encountered while processing: /var/cache/apt/archives/perl_5.24.1-3+deb9u4_armhf.deb E: Sub-process /usr/bin/dpkg returned an error code (1) # Zur "Kontrolle" nochmals ein "Upgrade" apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: libperl5.24 : Depends: perl-modules-5.24 (>= 5.24.1-3+deb9u4) but 5.24.1-3+deb9u3 is installed perl : Depends: perl-base (= 5.24.1-3+deb9u3) but 5.24.1-3+deb9u4 is installed Depends: libperl5.24 (= 5.24.1-3+deb9u3) but 5.24.1-3+deb9u4 is installed Recommends: rename but it is not installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution). # Ein reines 'apt --fix-broken install' bringt keine Loesung. Warum das so ist, kann vielleicht ein Debian Paketmanager sagen. # Vor dem 'apt --fix-broken install' muss man aber einige Pakete von Hand installieren. Die sind aber schon da. cd /var/cache/apt/archives/ dpkg -i perl-base_5.24.1-3+deb9u4_armhf.deb dpkg -i perl-modules-5.24_5.24.1-3+deb9u4_all.deb dpkg -i perl-base_5.24.1-3+deb9u4_armhf.deb dpkg -i perl-doc_5.24.1-3+deb9u4_all.deb apt --fix-broken install apt-get upgrade # Fertig! # Das "recommended" Paket "rename" habe ich nicht installiert. Saehe so aus: ## wget "http://ftp.de.debian.org/debian/pool/main/r/rename/rename_0.20-4_all.deb" ## dpkg -i rename_0.20-4_all.deb Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
