Author Topic: red brick no longer visible  (Read 2033 times)
tommichiels
  • Newbie
    • View Profile
« on: July 15, 2019, 11:39:02 »
After months of good service, my red brick is no longer visible in the brick viewer.   I tried to re-plug it, and eject and re-insert the SD card, but that did not help.    Any idea's?    Did my red brick die?
Thanks,
Tom
photron
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: red brick no longer visible
« Reply #1 on: July 15, 2019, 12:18:32 »
Please check if the three LEDs on the RED Brick light up in the documented sequence:
https://www.tinkerforge.com/en/doc/Hardware/Bricks/RED_Brick.html#leds
If they don't, what's the sequence you're seeing when you power up the RED Brick?
tommichiels
  • Newbie
    • View Profile
« Reply #2 on: July 15, 2019, 23:46:45 »
Thanks for the quick reply!
The sequence is stopped with a solid green light.
photron
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
« Reply #3 on: July 16, 2019, 11:10:25 »
Okay, that means that the RED Brick did not fully boot up. This can be an issue with the SD card itself or the file system on the SD card.
If you don't have any important data stored on the SD card then you could try flashing a fresh RED Brick image to the SD card:
https://www.tinkerforge.com/en/doc/Hardware/Bricks/RED_Brick.html#copy-image-to-sd-card
Alternatively, if you have another SD card similar to the RED Brick one then you could try flashing a fresh RED Brick image to that SD card instead.
