Author Topic: Announcements  (Read 142720 times)
borg
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #435 on: August 13, 2019, 14:43:23 »
Firmware: Thermal Imaging Bricklet 2.0.4
  • Double buffer lepton statistics to prevent statistics tearing
Download: Thermal Imaging
borg
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #436 on: August 19, 2019, 11:28:12 »
Firmware: Piezo Speaker Bricklet 2.0.3
  • Don't disable IRQs during calibration, since newer Brick versions use interrupts during I2C communication
Download: Piezo Speaker
photron
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #437 on: August 19, 2019, 17:15:46 »
Firmware: OLED 128x64 Bricklet 2.0 2.0.5
  • Make the clear-display function obey the automatic-draw config
Download: LCD 128x64 Bricklet 2.0 2.0.5
photron
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #438 on: August 23, 2019, 19:04:51 »
Bindings: C/C++ 2.1.26, C# 2.1.24, Delphi/Lazarus 2.1.25, Go 2.0.4, Java 2.1.24, JavaScript 2.1.24, LabVIEW 2.1.23, Mathematica 2.1.23, MATLAB/Octave 2.0.24, MQTT 2.0.7, Perl 2.1.24, PHP 2.1.23, Python 2.1.23, Ruby 2.1.23, Rust 2.0.12, Shell 2.1.23, Visual Basic .NET 2.1.23
  • Add support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0, Rotary Poti 2.0 and XMC1400 Breakout Bricklet [All]
  • Add Get/SetFilterConfiguration functions to Accelerometer Bricklet 2.0 API [All]
  • Add ConversionTime constants to Voltage/Current Bricklet 2.0 API [All]
  • Fix misaligned array access in callback wrapper function [C/C++]
  • Don't leak the get_random_uint32 symbol [C/C++]
  • Break API to stop mixing object and function pointers for callback functions [C/C++]
  • Allow to pass non-constant values to parameters with constants [Go]
  • Break API to remove enumerate response structure: enumerate callback uses parameters directly, which is more in line with all other callbacks [Go]
  • Increase minimum JDK version from 1.6 to 8 [Java]
  • More robust connection handling [MQTT]
  • Fix init file loading [MQTT]
Download: C/C++, C#, Delphi/Lazarus, Go, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, MQTT, Perl, PHP, Python, Ruby, Rust, Shell, Visual Basic .NET
« Last Edit: August 26, 2019, 11:10:18 by photron »
photron
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #439 on: August 26, 2019, 11:59:41 »
Brick Viewer 2.4.7
  • Add Data Logger support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0 and Rotary Poti 2.0 Bricklet
  • Fix latest firmware version discovery if no Internet connection is available
  • Add interpolation and scale factor options to Thermal Imaging Bricklet plugin
  • Download firmware files using HTTPS
  • Updates/Flashing dialog can download Brick Viewer updates
  • Fix WIFI Extension 2.0 flashing to fix web interface
  • Don't try to use invalid IMU Brick calibration
  • Don't crash if OpenGL is not available
  • Correctly handle Modbus response with unknown request in RS485 Bricklet plugin
Downloads: Windows, Linux, macOS
photron
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #440 on: August 26, 2019, 15:15:08 »
Brick Logger 2.1.1
  • Add support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0 and Rotary Poti 2.0 Bricklet
Downloads: Windows, Linux, macOS, RED Brick
photron
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #441 on: August 27, 2019, 12:18:02 »
Brick Viewer 2.4.8
  • Fix firmware download on newer macOS versions
borg
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #442 on: August 28, 2019, 11:28:36 »
Firmware: Air Quality Bricklet 2.0.5
  • Update Bosch BSEC to v1.4.7.4
  • Improve outlier value handling
Download: Air Quality
borg
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #443 on: August 28, 2019, 12:19:54 »
Firmware: CO2 V2 Bricklet 2.0.2
  • Improve I2C error handling
Download: CO2 2.0
photron
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #444 on: September 02, 2019, 20:39:22 »
Brick Viewer 2.4.9
  • Fix Bricklet auto-update crash
  • Allow to choose other versions than the latest when flashing firmwares
  • Allow to write hex bytes in hex mode in RS485 Bricklet plugin
  • Allow to specify coil/register values when writing multiple coils/registers in RS485 Bricklet plugin
  • Delete key works correct in RED Brick plugin console tab
borg
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #445 on: September 09, 2019, 10:01:42 »
Firmware: Joystick V2 Bricklet 2.0.2
  • Fix bug in callback handler
Download: Joystick 2.0
borg
  • Tinkerforge Staff
  • Administrator
  • Hero Member
    • View Profile
Re: Announcements
« Reply #446 on: September 09, 2019, 14:10:57 »
Firmware: Energy Monitor Bricklet 2.0.1
  • Show voltage and current of 0 if the waveform has no zero-crossings
Download: Energy Monitor
