Atak Geschrieben September 18, 2012 at 01:34 Share Geschrieben September 18, 2012 at 01:34 I was thinking you guys would have it set up where I would have to have 2 wifi extensions... one connected to the computer and another connected to whatever im running with wireless. Now I see that I just need one wifi extension which is awesome. So when connecting to the wifi extension, do I need a brick connected whatsoever to my computer? Or do I just use brickv to connect to my wireless router and control everything from that? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben September 18, 2012 at 07:32 Share Geschrieben September 18, 2012 at 07:32 You can directly connect to a Stack with WIFI Extension. There is no need for brickd if you use the WIFI Extension (brickd is implemented on the Master Brick for this). Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Cathodion Geschrieben September 18, 2012 at 13:49 Share Geschrieben September 18, 2012 at 13:49 You can directly connect to a Stack with WIFI Extension. There is no need for brickd if you use the WIFI Extension (brickd is implemented on the Master Brick for this). Nice work fellas! Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
