Hello,
First of all, I'm beginner with python and tinkerforge brick/briklet.
I have a system with hat brick + 2 IMU V3 Bricklet + 1 GPS V3 bricklet. My script run well to acquire data and do what I want, which is a good thing. But, I can't manage to set the status led config for IMU(s). I would like to set the led to heartbeat when my system is recording but I can't manage to do it.
I tried this after ipcon.connect(...) :
BrickletIMUV3.set_status_led_config(2)
It gives me this error :
TypeError: set_status_led_config() missing 1 required positional argument: 'config'
Does some one could help me for this ?
Thanks in advance
You have to call "set_status_led_config(2)" on the IMU object you created before.
You probably have something like this in your code:
imu = BrickletIMUV3(UID, ipcon)
Afterwards, set the LED config like this:
imu.set_status_led_config(2)
Have a look at one of the IMU examples and note how "get_quaternion()" is used on the "imu" object.
×   Du hast formatierten Text eingefĂĽgt.   Formatierung jetzt entfernen
×   Dein Link wurde automatisch eingebettet.   Einbetten rĂĽckgängig machen und als Link darstellen
×   Du kannst Bilder nicht direkt einfĂĽgen. Lade Bilder hoch oder lade sie von einer URL.
