  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
HAT brick with a Jetson Orin Nano?
Did anybody try by chance already to use the HAT brick with a Jetson Orin Nano?
Be the first to try it! 😉
The Brick Daemon to communicate with the HAT Brick supports the Linux spidev driver and if the Jetson Orin Nano supports that, you can set up the pin configuration manually. See here for more information.
