October 25, 2026 at 02:31 PMOct 25, 2026 I use evcc + Warp4Pro + ID4 (2025, latest sw).Charging works fine if started directly once connected. It also seems to work find if charging was started, got paused due to energy management and is restarted later.What appears to NOT work is if connected, no charging is done for some minutes and later on charging is initialized through evcc. In this case evcc indicates "Waiting for vehicle". Warp4 states "Ladebereit". But charging does not start. I did a litle bit of testing and I got the feeling disabling "Ladestand vom Fahrzeug per ISO 15118 auslesen" might solve the problem but I like to keep that feature.The ID4 charge LED is off in this case. So: Is this a known problem? Any ideas?
October 25, 2026 at 04:02 PMOct 25, 2026 This is a known problem with VW cars. You have to enable „Welcome charge“ or „Initial charge“ for your vehicle in evcc. That will fix it.
October 25, 2026 at 08:31 PMOct 25, 2026 Author Am 25.10.2026 um 17:02 schrieb MatzeTF: This is a known problem with VW cars. You have to enable „Welcome charge“ or „Initial charge“ for your vehicle in evcc. That will fix it.Thanks! So Iso15118 can remain enabled?I assume you are referring to the evcc vehicle option „Laden bei Verbindung“At least the first try seemed positive!
October 25, 2026 at 11:04 PMOct 25, 2026 On 10/25/2026 at 9:31 PM, Hannes12 said:Thanks! So Iso15118 can remain enabled?I assume you are referring to the evcc vehicle option „Laden bei Verbindung“Yes and yes.
October 29, 2026 at 05:14 AMOct 29, 2026 Same issue and same fix confirmed for a Škoda Elroq (MY 2027, MEB) with WARP4 Pro (FW 2.13.5) and evcc 0.318: with ISO 15118 (Autocharge + SoC readout) enabled the car didn't start charging after a night in standby; with evcc's "welcome charge" ("Laden bei Verbindung" in the German UI) enabled it now starts reliably with ISO 15118 on. Thanks!
