November 5, 2026 at 06:13 AMNov 5, 2026 Firmware: WARP4 Charger Pro, 2.13.6An API meter fed every second via MQTT (<prefix>/meters/2/update) has no value for about 10–12 s, roughly every 15 minutes. I see it in the live data of that meter (/meters/live, the meter's live chart): the samples are empty for that period. The internal meter (meter 0) has values the whole time. The event log shows nothing at those moments.The update messages do arrive at the broker every second without interruption. The charger is reachable on the network and keeps publishing its own topics normally.Possible causeEach hole starts right after the charger republishes its Home Assistant discovery messages, which happens every 15 minutes after the start of the WARPAfter switching off autodiscovery the meter does not have the 10-12 sec gaps anymore. I was troubleshooting my own automation that uses M2 to insert values, and make the regulation adapting specifically to the Belgian tariff structure. So just came across this while claude was analysing the results of my own control flow.the hole appears on all meters fed by MQTT.540:407541:407542:407543:407544:407545:null546:null547:null548:null549:null550:null551:null552:null553:null554:null555:null556:null557:null558:null559:null560:null561:null562:null563:null564:null565:null566:403567:402
November 5, 2026 at 08:20 AMNov 5, 2026 Am 5.11.2026 um 07:13 schrieb Johan: After switching off autodiscovery the meter does not have the 10-12 sec gaps anymore.Interesting, i wonder if it is a CPU load issue or a network load issue. Do you use MQTT oder MQTTs?When we introduced the new auto discovery values, there where some bugs first and i did a bunch of testing for these bugs, i never noticed these slow downs though.I will take a look at the issue.
November 5, 2026 at 08:28 AMNov 5, 2026 Author Hi,I am not an expert in your software and was going to spare you the explanation claude gave me. But it told me the warp publishes all the discovery values and reads them back in (subscribed to itself). During that time it seems to be blocking the reading of incoming values from other sources.I don't trust AI enough to put my money on it though, at best it is a hint in something it correlated to.
November 5, 2026 at 09:10 AMNov 5, 2026 I was able to reproduce it. Each time we send the discovery message there was a check for all 135 topics we subscribe to internally with a sleep of up to 100ms each. Fixed it here: https://github.com/Tinkerforge/esp32-firmware/commit/952539bfe8fee220dfe30d70c7934f2d6e5acd05
