LAN connection problem
Hello,
I have a new Warp2 Pro charger with FW 1.1.0. The LAN Connection interrupts always after a couple of minutes .
Device disappears and can not be accessed via LAN ip address.
WLAN works fine.
A reconnection of LAN cable does not help.
The box needs always to be disconnected from power for a short time.
LAN configuration is DHCP.   FritzBox uses always same ip address.
Markus
On 11/26/2021 at 8:10 PM, markus.p said:
WLAN works fine.
If you can still reach the web interface over WLAN when the LAN connection is interrupted, please download a debug report (System -> Event-Log -> Download debug report and event log) and post it here.
Hello,
I do not want to attach the log file to this chat since there are some NW details inside.
Can you provide me a email address for log file upload.
What I can see as last 2 lines within the log file are:
12127       MQTT: Connected to broker.
95633       httpd_ws_recv_frame failed to get frame len with 259
The rest looks Ok. There are not any errors.
Markus
Status Screen:
"Verbinde" stays all the time until power reset cycle
  • 4 months later...
I have the same problem or very similar problem. I cannot connect to the Webserver via Ethernet. Log also showing
Is there a official solution for that?
Thank you,
Adriano
Do you also get "Verbinde" or "Connecting" as LAN/ethernet status? In this case the problem is usually with the ethernet cable. Also we've had one case where the router that the charger was connected to had a non-working ethernet port.
The log message indicates that a WebSocket frame could not be sent, however if you can't load the Webinterface at all, there is no WebSocket connection. So this is likely a message generated when you disconnect from the chargers WiFi access point.
