yvo Geschrieben June 27, 2025 at 17:40 Geschrieben June 27, 2025 at 17:40 Dear list I have to monitor a sensor which consumes <=30mA if it works or not (e.g. disconnected cable). My amateur-approach would be, to add a Voltage/Current-bricklet between the PowerSupply and the sensor to check, if there is power-consumption by the sensor. The fact-sheet of the sensor to be monitored tells me "Power consumption max. without load ≤ 30 mA". The sensor is connected to a 24V PowerSupply. I tried to understand the fact-sheet of the INA226 used by the Voltage/Current-Bricklet. But I wasn't able to understand, if the above mentioned ≤ 30 mA can be measured. Question: What is your opinion? Is it feasible to measure such small power-consumption by the Voltage/Current-Bricklet? Looking forward to any ideas and hints. Cheers. Yvo Zitieren
MatzeTF Geschrieben June 27, 2025 at 18:55 Geschrieben June 27, 2025 at 18:55 The Voltage/Current Bricklet can measure currents with 1 mA accuracy, starting at 1 mA. As long as the sensor consumes at least 1 mA when active, you should be able to monitor it. 1 Zitieren
yvo Geschrieben June 28, 2025 at 08:37 Autor Geschrieben June 28, 2025 at 08:37 Am 27.6.2025 um 20:55 schrieb MatzeTF: The Voltage/Current Bricklet can measure currents with 1 mA accuracy, starting at 1 mA. As long as the sensor consumes at least 1 mA when active, you should be able to monitor it. Great. Thank you very much for the fast replay. I am able to test it next Tuesday when I am at fieldwork. I will let you know, how it worked. Zitieren
