Are <=30mA to be measured with a Voltage/Current Bricklet?
Dear list
I have to monitor a sensor which consumes <=30mA if it works or not (e.g. disconnected cable). My amateur-approach would be, to add a Voltage/Current-bricklet between the PowerSupply and the sensor to check, if there is power-consumption by the sensor.
The fact-sheet of the sensor to be monitored tells me "Power consumption max. without load ≤ 30 mA". The sensor is connected to a 24V PowerSupply.
I tried to understand the fact-sheet of the INA226 used by the Voltage/Current-Bricklet. But I wasn't able to understand, if the above mentioned ≤ 30 mA can be measured.
Question:
Looking forward to any ideas and hints.
Cheers. Yvo
Am 27.6.2025 um 20:55 schrieb MatzeTF:
The Voltage/Current Bricklet can measure currents with 1 mA accuracy, starting at 1 mA.
As long as the sensor consumes at least 1 mA when active, you should be able to monitor it.
Great. Thank you very much for the fast replay. I am able to test it next Tuesday when I am at fieldwork. I will let you know, how it worked.
I just tested the Current/Voltage-Bricklet in combination with the sensor:
  • Just works perfectly. The resolution and the minimal value of the bricklet allows the monitoring of the sensor.
Cheers. Yvo
