Hall Effect bricklet question
Can anyone at TF explain the reasoning why the Hall Effect bricklet doesn't give us any field strength measuring capabilities? I mean, I understand the underlying chip is designed as a switch, not a metering sensor.. but is there a good reason why you didn't go with something that could simply give us a strength value, like so many of the other bricklets do?
