Geschrieben July 16, 2016 at 12:1716. Jul 2016 Hi, is there guidance available on how to use the TinkerForge Javascript Bindings in Node-RED. Have tried to define a simple call to an ambilight bricklet in a Node-RED function, but received error 31=timeout. //var Tinkerforge = require('/usr/lib/node_modules/tinkerforge'); var Tinkerforge = context.global.tinkerforge; var HOST = '192.168.0.88'; var PORT = 4223; var UID = 'mdh'; var ipcon = new Tinkerforge.IPConnection(); var al = new Tinkerforge.BrickletAmbientLight(UID, ipcon); ipcon.connect(HOST, PORT, function (error) { node.warn('Connect Error: ' + error); } ); ipcon.on(Tinkerforge.IPConnection.CALLBACK_CONNECTED, function (connectReason) { al.getIlluminance( function (illuminance) { msg.payload = "{\"Illuminance\":" + illuminance/10.0 + "}"; node.warn('Illuminance: ' + illuminance/10.0 + ' Lux'); }, function (error) { msg.payload = "{\"lluminance\":" + error + "}"; node.warn('Get Error: ' + error); } ); } ); ipcon.disconnect(); return msg; Note: defined in node-red settings, after installing tinkerforge via npm: functionGlobalContext: { tinkerforge:require('/usr/lib/node_modules/tinkerforge')
Geschrieben July 18, 2016 at 14:1818. Jul 2016 Autor Solved by using the MQTT proxy as broker on localhost:1883. Defined a simple test flow with: Input Node "MQTT In" subscribing to topic "tinkerforge/bricklet/ambient_light/mdh/illuminance"Function Node JSON to convert MQTT string to javascript objectFunction Node Function to log the payload properties illuminance and _timestampDebug Node to log the MQTT payload (which is a JSON string) Looks promising to explore further integration of TinkerForge in Node-RED.
Geschrieben July 25, 2016 at 10:1625. Jul 2016 I've been working on some Node-RED Tinkerforge nodes Feel free to kick the tires https://github.com/hardillb/node-red-contrib-tinkerforge All feedback welcome. P.S. A guess about the error you had will be that you probably need a use the v2 Ambient Light Object if you have a v2 bricklet
Geschrieben July 25, 2016 at 13:5725. Jul 2016 Autor Great and Thanks a lot. Could you pls advice how to install in Node-RED? Tried npm install node-red-contrib-tinkerforge, but npm can not find the package.
Geschrieben July 25, 2016 at 15:0225. Jul 2016 Autor UPDATE Installed: $sudo npm install -g tinkerforge Added to NODE_PATH: $export NODE_PATH=$NODE_PATH:/usr/local/lib/node_modules Installed: $npm install body-parser in the .node-red folder under node_modules Created folder: /home/pi/.node-red/node_modules/node-red-contrib-tinkerforge Copied the lib folder and other files to node-red-contrib-tinkerforge Started node-red TinkerForge nodes available COOL Added the ambientlight (v1) sensor by amending lib/bricklets.js, tinkerforge.js & tinkerforge.html. Again Thanks a Lot = Job Well Done
Geschrieben July 25, 2016 at 15:0825. Jul 2016 It's not been packaged for npm just yet but you can npm install direct from github with the following: npm install hardillb/node-red-contrib-tinkerforge If you run this in /home/pi/.node-red it will end up in the right place I have only done a Ambient light v2.0 node as that's the only hardware I have available to test. But it should be pretty simple do v1.0 node if somebody can let me know the deviceIdentifier.
Geschrieben July 25, 2016 at 17:1525. Jul 2016 Autor Thanks Have added AmbientLight and UVLight (see attachement). Working fine. The TF device identifies can be found www.tinkerforge.com/en/doc/Software/Device_Identifier.html. Next: New LED Bricklet with ability to set the color = will use the LED strip as example. 20160725: Correction to AmbientLight (see attachment) v11.zip
Geschrieben July 27, 2016 at 08:4727. Jul 2016 Thanks for the link to the device identifiers. Rather than posting zips of code changes here, a pull request on github would be great so we can track the changes. Thanks
Geschrieben November 19, 2016 at 14:0519. Nov 2016 I have brickd running on a Pi with a Master Brick and Analogue Out v2 connect on port D connected by USB. I am trying to control from Node Red and have installed node-red-contrib-tinkerforge. Brickviewer on the Pi can detect the master and analogue bricklet and can adjust the output correctly, so brickd seems to be working. Node red Analogue out node detects the Analogue node id correctly but does not change the output. The config is localhost:4223 which is the same as Brickviewer on the Pi. Any suggestions would be appreciated
Geschrieben January 18, 2017 at 16:2518. Jan 2017 Hi...i am a new user here. I think you can npm install direct from github with the following:npm install hardillb/node-red-contrib-tinkerforge If you run this in /home/pi/.node-red it will end up in the right place.I have only done a Ambient light v2.0 node as that's the only hardware I have available to test. But it should be pretty simple do v1.0 node if somebody can let me know the device Identifier. printed circuit board assembly
