Ming Geschrieben January 14, 2017 at 22:03 Geschrieben January 14, 2017 at 22:03 Moin, ich habe ein Problem mit einem Remote Switch. Es fubnktioniert alles, wenn der Master direkt mit dem Rechner verbunden ist. Wird er über einen Red Brick angesprochen, bleibt der Brickviewer hängen. Das Problem haben schon mehrere User berichtet. Ich hab mal das Log des Brickdeamons angehängt. Der Daemon muß danach neu gestartet werden... Was kann ich tun? Ming 2017-01-14 22:42:54.893966 <I> <main_macosx.c:148> Brick Daemon 2.2.3 started (pid: 37784, daemonized: 1) 2017-01-14 22:42:54.938817 <I> <usb.c:191> Added USB device (bus: 253, device: 3) at index 0: RED Brick [2Fuoqp] 2017-01-14 22:44:16.335388 <W> <libusb:darwin_transfer_status> transfer error: device not responding (value = 0xe00002ed) 2017-01-14 22:44:16.335451 <W> <usb_transfer.c:116> Read transfer 0x7ff385810ce0 (0x7ff383f01568) returned with an error from RED Brick [2Fuoqp]: LIBUSB_TRANSFER_ERROR (1) 2017-01-14 22:44:16.335567 <E> <libusb:submit_bulk_transfer> bulk transfer failed (dir = In): pipe is stalled (code = 0xe000404f) 2017-01-14 22:44:16.335589 <E> <usb_transfer.c:281> Could not submit read transfer 0x7ff385810ce0 (0x7ff383f01568) to RED Brick [2Fuoqp]: LIBUSB_ERROR_PIPE (-9) 2017-01-14 22:44:16.347761 <I> <usb.c:388> Removing USB device (bus: 253, device: 3) at index 0: RED Brick [2Fuoqp] 2017-01-14 22:44:16.347828 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.347859 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810c00 (0x7ff383f012e8) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.347883 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810c00 (0x7ff383f012e8) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.347933 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.347948 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810c70 (0x7ff383f01428) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.347959 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810c70 (0x7ff383f01428) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.347977 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.347987 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810d50 (0x7ff383f016a8) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.347997 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810d50 (0x7ff383f016a8) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.348008 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.348017 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810dc0 (0x7ff383f017e8) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.348027 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810dc0 (0x7ff383f017e8) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.348037 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.348046 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810e30 (0x7ff383f01928) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.348056 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810e30 (0x7ff383f01928) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.348066 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.348075 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810ea0 (0x7ff383f01b38) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.348084 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810ea0 (0x7ff383f01b38) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.348095 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.348104 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810f10 (0x7ff383f01c78) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.349519 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810f10 (0x7ff383f01c78) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.349540 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.349549 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810f80 (0x7ff383f01db8) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.349559 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810f80 (0x7ff383f01db8) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.349569 <W> <libusb:darwin_abort_transfers> aborting all transactions on interface 0 pipe 1 2017-01-14 22:44:16.349578 <W> <usb_transfer.c:191> Could not cancel pending read transfer 0x7ff385810ff0 (0x7ff383f01ef8) for RED Brick [2Fuoqp]: LIBUSB_ERROR_NO_DEVICE (-4) 2017-01-14 22:44:16.349587 <W> <usb_transfer.c:227> Leaking pending read transfer 0x7ff385810ff0 (0x7ff383f01ef8) for RED Brick [2Fuoqp] 2017-01-14 22:44:16.349691 <W> <libusb:darwin_close> USBDeviceClose: no connection to an IOService Zitieren
photron Geschrieben January 16, 2017 at 16:26 Geschrieben January 16, 2017 at 16:26 Teste mal bitte diese Version. brickd_macos_2_2_3_hf1.dmgFetching info... Zitieren
Ming Geschrieben January 16, 2017 at 19:29 Autor Geschrieben January 16, 2017 at 19:29 Moin, das hat leider nicht geholfen. Aber ich habe folgendes beobachtet. Setup: brickd und viewer auf Mac, jeweils neuste Version. Auf dem red brick läuft der daemon 2.2.2 wie vorinstalliert. 2017-01-16 20:22:23.701101 <I> <red_usb_gadget.c:140> Disconnected from RED Brick USB gadget 2017-01-16 20:22:28.838024 <I> <main_linux.c:281> Brick Daemon 2.2.2+redbrick started (pid: 6735, daemonized: 1) 2017-01-16 20:22:28.897408 <I> <usb.c:154> Added USB device (bus: 1, device: 5) at index 0: RED Brick [2Fuoqp] 2017-01-16 20:22:30.525431 <I> <red_extension.c:524> Could not find Extension at position 0 2017-01-16 20:22:30.525931 <I> <red_extension.c:524> Could not find Extension at position 1 2017-01-16 20:22:30.526311 <I> <network.c:373> Added new client (N: g_red_brick, T: file, H: 28, A: disabled) 2017-01-16 20:22:30.526379 <I> <red_usb_gadget.c:115> Connected to RED Brick USB gadget 2017-01-16 20:22:30.532292 <I> <redapid.c:309> Connected to RED Brick API Daemon 2017-01-16 20:22:31.282331 <I> <red_stack.c:531> SPI stack slave discovery done. Found 1 slave(s) with 2 UID(s) in total Dann connecte ich den brickviewer auf meinem Mac: 2017-01-16 20:24:24.702712 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.705828 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.707427 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.709507 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.711443 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.716966 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.721605 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.723460 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.726523 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.728876 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.730586 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.735866 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.737744 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.739373 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.742309 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) endlose wiederholungen, dann kommt: 2017-01-16 20:24:24.870223 <W> <network.c:541> Broadcasting response (U: 68y3Ww, L: 9, F: 5, S: 12, E: 0) because no client/zombie has a matching pending request 2017-01-16 20:24:24.871871 <W> <network.c:541> Broadcasting response (U: 68y3Ww, L: 9, F: 5, S: 12, E: 0) because no client/zombie has a matching pending request 2017-01-16 20:24:24.873485 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.875334 <W> <network.c:541> Broadcasting response (U: 68y3Ww, L: 9, F: 5, S: 12, E: 0) because no client/zombie has a matching pending request 2017-01-16 20:24:24.876981 <W> <network.c:541> Broadcasting response (U: 68y3Ww, L: 9, F: 5, S: 12, E: 0) because no client/zombie has a matching pending request 2017-01-16 20:24:24.878448 <W> <network.c:541> Broadcasting response (U: 68y3Ww, L: 9, F: 5, S: 12, E: 0) because no client/zombie has a matching pending request 2017-01-16 20:24:24.880187 <W> <network.c:541> Broadcasting response (U: 68y3Ww, L: 9, F: 5, S: 12, E: 0) because no client/zombie has a matching pending request 2017-01-16 20:24:24.881849 <W> <network.c:269> Dropped 1 pending request(s) (uid: 2Fuoqp) 2017-01-16 20:24:24.882660 <W> <network.c:541> Broadcasting response (U: 68y3Ww, L: 9, F: 5, S: 12, E: 0) because no client/zombie has a matching pending request 2017-01-16 20:24:24.883336 <W> <network.c:541> Broadcasting response (U: 68y3Ww, L: 9, F: 5, S: 12, E: 0) because no client/zombie has a matching pending request ...... dann kommt: 2017-01-16 20:25:27.483980 <W> <network.c:440> Pending requests list for client (N: g_red_brick, T: file, H: 28, A: disabled) is full, dropping 1 pending request(s) 2017-01-16 20:25:27.485280 <W> <writer.c:108> Write backlog for client (N: g_red_brick, T: file, H: 28, A: disabled) is full, dropping 1 queued response(s), 50384 +1 dropped in total 2017-01-16 20:25:27.485949 <W> <network.c:440> Pending requests list for client (N: g_red_brick, T: file, H: 28, A: disabled) is full, dropping 1 pending request(s) 2017-01-16 20:25:27.487165 <W> <writer.c:108> Write backlog for client (N: g_red_brick, T: file, H: 28, A: disabled) is full, dropping 1 queued response(s), 50385 +1 dropped in total 2017-01-16 20:25:27.488486 <W> <writer.c:108> Write backlog for client (N: g_red_brick, T: file, H: 28, A: disabled) is full, dropping 1 queued response(s), 50386 +1 dropped in total 2017-01-16 20:25:27.489602 <W> <network.c:440> Pending requests list for client (N: g_red_brick, T: file, H: 28, A: disabled) is full, dropping 1 pending request(s) 2017-01-16 20:25:27.491188 <W> <writer.c:108> Write backlog for client (N: g_red_brick, T: file, H: 28, A: disabled) is full, dropping 1 queued response(s), 50387 +1 dropped in total 2017-01-16 20:25:27.492118 <W> <writer.c:108> Write backlog for client (N: 192.168.188.24:53420, T: plain-socket, H: 30, A: disabled) is full, dropping 1 queued response(s), 50302 +1 dropped in total das läuft dann endlos und schreibt mehrere megabytes pro minute logs. Zitieren
Ming Geschrieben January 16, 2017 at 20:11 Autor Geschrieben January 16, 2017 at 20:11 Und was mir noch auffällt, auf dem redbrick zieht der brickd ezxtrem an der cpu: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 3343 root 20 0 18384 888 684 R 67.6 0.2 0:50.02 brickd Der red wurde frisch gebootet und tut nichts. Log: 2017-01-16 21:08:15.392507 <I> <usb.c:154> Added USB device (bus: 1, device: 5) at index 0: RED Brick [2Fuoqp] 2017-01-16 21:08:17.020580 <I> <red_extension.c:524> Could not find Extension at position 0 2017-01-16 21:08:17.022756 <I> <red_extension.c:524> Could not find Extension at position 1 2017-01-16 21:08:17.024284 <I> <network.c:373> Added new client (N: g_red_brick, T: file, H: 28, A: disabled) 2017-01-16 21:08:17.025226 <I> <red_usb_gadget.c:115> Connected to RED Brick USB gadget 2017-01-16 21:08:17.031719 <I> <redapid.c:309> Connected to RED Brick API Daemon 2017-01-16 21:08:18.037112 <I> <red_stack.c:531> SPI stack slave discovery done. Found 1 slave(s) with 2 UID(s) in total Zitieren
photron Geschrieben January 17, 2017 at 09:45 Geschrieben January 17, 2017 at 09:45 Okay, da ist irgend was grob faul Wenn du sagst, dass die neue brickd Version für den Mac nicht geholfen hat, dann meinst du, dass brickd auf dem Mac immer noch diese Fehler aus deinem ersten Post ausgibt, abstürzt und dann von Hand neugestartet werden muss? Ist UID 68y3Ww ein Master Brick, oder was für ein Brick ist das? Ist IP Adresse 192.168.188.24 der Mac? Kannst du dir auch mal die /var/log/redapid.log Datei auf dem RED Brick ansehen? Zitieren
