Solution communicating via virtual COM
Hello,
working now on solution (see attached diagram) where I need to modify firmware of Silent Stepper Brick a little bit, for reading Digital Indicator values.
Also Master Brick should be connected to USB port on PC, but appear as virtual COM (RS232), to be able to send and recive simply commands and aswers this way, instead of using API and TCP/IP connection. How to do this?
Also need some simply communication with custom Bricklet via I2C.
Should I use Debug Brick to modify the firmware? Can I use Atmel Studio with AVR Dragon programator for this?
Best regards
Tomáš
Motor_control_diagram.pdf
