About voltage-current-v2-bricklet
Hello, I dowloaded some example files,but i couldn't find like
#include "xmc_spi.h" #include "xmc_device.h"
#include "xmc_gpio.h"
what are kinds of files, where can i find them?
Thank you.
I think you mistook the firmware source code of the Voltage/Current Bricklet 2.0 as example code.
I assume you don't want to modify the firmware of the Bricklet, but you want to use the Bricklet as is.
You can find the C/C++ examples for the Voltage/Current Bricklet 2.0 here as part of the API documentation:
https://www.tinkerforge.com/en/doc/Software/Bricklets/VoltageCurrentV2_Bricklet_C.html
or here on GitHub:
https://github.com/Tinkerforge/voltage-current-v2-bricklet/tree/master/software/examples/c
You'll need the C/C++ API bindings to compile the examples:
https://download.tinkerforge.com/bindings/c/tinkerforge_c_bindings_2_1_32.zip
The ZIP also contains the C/C++ examples for the Voltage/Current Bricklet 2.0 at examples/bricklet/voltage_current_v2.
achso, thank you so much!!!!!!
