Is this a know issue: Exception if more than 4 bricklets are connected.
            { Get current temperature (unit is °C/100) }
            //t1_val := StringReplace (FloatToStrF(t1.GetTemperature/100 + t1_Korr, ffFixed, 8,2),'.',',',[rfReplaceAll]) ;
            //t2_val := StringReplace (FloatToStrF(t2.GetTemperature/100 + t2_Korr, ffFixed, 8,2),'.',',',[rfReplaceAll]) ;
            t3_val := StringReplace (FloatToStrF(t3.GetTemperature/100 + t3_Korr, ffFixed, 8,2),'.',',',[rfReplaceAll]) ;
            t4_val := StringReplace (FloatToStrF(t4.GetTemperature/100 + t4_Korr, ffFixed, 8,2),'.',',',[rfReplaceAll]) ;
            t5_val := StringReplace (FloatToStrF(t5.GetTemperature/100 + t5_Korr, ffFixed, 8,2),'.',',',[rfReplaceAll]) ;
            t6_val := StringReplace (FloatToStrF(t6.GetTemperature/100 + t6_Korr, ffFixed, 8,2),'.',',',[rfReplaceAll]) ;
            { get pressure & humidity }
            //h1_val := StringReplace (FloatToStrF(h1.GetHumidity/10  + h1_Korr, ffFixed, 8,2),'.',',',[rfReplaceAll]) ;
            //b1_val := StringReplace (FloatToStrF(b1.GetAirPressure/1000  + b1_Korr, ffFixed, 8,2),'.',',',[rfReplaceAll]) ;
If h1 or/and b1 will be (more than 4 brickletts) requested there is an exception:
External: SIGSEGV
    end;
    errorCode := GetErrorCodeFromData(result);
    if (errorCode = 0) then begin
This occures in all combinations.
So the h1_val throws an exception if you comment it in, but it doesnt if you comment out te tX_val lines? That doesn't make sense :).
Can you make a minimal Program (including the initialization and so) that causes the exception?
Solved! Lazarus was confused. After restarting Lazarus and new compiler run all works fine.  8)
