[ERROR] RPi 5 Bookworm brickd failed after update
updated both brickv & brickd on a RPi5 running Bookworm.
The brickd start error:
brickd: error while loading shared libraries: libudev.so.1: ELF load command address/offset not page-aligned
Updated using:
echo ------------------
echo Brick Daemon
sudo apt-get -y install libusb-1.0-0 libudev0 pm-utils
sudo wget https://download.tinkerforge.com/tools/brickd/linux/brickd_linux_latest_armhf.deb
sudo dpkg -i brickd_linux_latest_armhf.deb
echo Done
echo Brick Viewer
sudo apt-get install -y python3 python3-pyqt5 python3-pyqt5.qtopengl python3-serial python3-tz python3-tzlocal
sudo wget https://download.tinkerforge.com/tools/brickv/linux/brickv_linux_latest.deb
sudo dpkg -i brickv_linux_latest.deb
echo Done
The error suggests that you’re not running armhf but rather arm64.
Please use the Tinkerforge repository instead of trying to install the packages manually. Using the repository will always get you the correct version and you will automatically receive updates as well.
  • Uninstall brickd
  • Follow these instructions to set up the repository
  • Install brickd via apt-get
Thanks for the guidance = working on the RPi 5 Bookworm.
echo Brick Daemon
echo Done
echo Brick Viewer
echo Done
Actually, where did you find this script?
Think it is 5 or 6 years old.
It was based on the Tinkerforge documentation at that time. Script had been working ok until recently.
