Geschrieben February 5, 2026 at 09:305. Feb 2026 Dear ListI am using Bricks and Bricklets in distributed hardware in many remote locations. Usually, the bricklets are accessed by software running locally at the remote locations.What is missing from my side, is a monitoring-tool, which checks the availability and health of the individual bricklets at the locations. To have an information about the health and availability of the bricks and bricklets, I am thinking to implement a piece of software running as service, e.g. TinkerforgeWatcher.The TinkerforgeWatcher will have a configuration-file containing a list of all bricks and bricklets to be monitor at the specific location. Using a monitoring-service, like Prometheus, the TinkerforgeWatcher will submit in a defined rate the health of all bricklets.Basically, it will submit an OK or a NOK for each bricklet.Now the question:What kind of function would you use to check the health of a bricklet?Currently, I have the impression, that *.get_spitfp_error_count() would be the most suitable function to have a first impression about the health of a bricklet.Looking forward to any suggestions.Cheers. Yvo
Geschrieben February 5, 2026 at 21:255. Feb 2026 This is what I do: I keep a registry of all Tinkerforge devices in a YAML file:--- devices: 21LQ: inventory: name: GPS Bricklet 3.0 identifier: 2171 first seen: 2026-01-29 08:21:30 UTC last seen: 2026-01-29 08:21:30 UTC firmware: 2.0.0 connected: YwJ position: B host: esp1.local port: 4223 settings: fix_led_config: 1 status_led_config: 0 # 331 Lines skipped for brevity RvX: inventory: name: Outdoor Weather Bricklet identifier: 288 first seen: 2022-06-06 13:05:32 UTC last seen: 2026-01-28 08:14:32 UTC firmware: 2.0.4 connected: S2c position: c host: p3.local port: 4223 settings: status_led_config: 0 sensormap: 74: inside 61: outside 223: fridge # Et cetera...A little script regularly connects to all hosts, finds all devices through discovery, and updates the registry. Newly found devices automatically get added. Devices that stopped responding will have a stale 'last seen' value. YAML file sits in a Git repo.
