[PHP] Servo Programmierung zur LED Steuerung
ich bin gerade dabei mit dem Servo-PWM-Signal einen RGB-LED-Strip (keinen digitalen) anzusteuern.
Mit dem BrickV klappt das schon ganz gut. Mit PHP will es nicht.
Hier mein Code:
$this->serv_red = 4;
$this->serv_green = 5;
$this->serv_blue = 6;
$this->tinker_conn = new Tinkerforge\IPConnection();
$this->tinker_serv = new Tinkerforge\BrickServo( tfUID_SERVO, $this->tinker_conn );
$this->tinker_conn->connect( tfHOST, tfPORT );
$this->tinker_serv->setOutputVoltage(9000);
        // blue
        $this->tinker_serv->setDegree($this->serv_blue, 0, 0);
        $this->tinker_serv->setPulseWidth($this->serv_blue, 1000, 2000);
        $this->tinker_serv->setPeriod($this->serv_blue, 1);
        $this->tinker_serv->setAcceleration($this->serv_blue, 0); // Slow acceleration
        $this->tinker_serv->setVelocity($this->serv_blue, 0); // Full speed
        // red
        $this->tinker_serv->setDegree($this->serv_red, 0, 0);
        $this->tinker_serv->setPulseWidth($this->serv_red, 1000, 2000);
        $this->tinker_serv->setPeriod($this->serv_red, 7000);
        $this->tinker_serv->setAcceleration($this->serv_red, 0); // Slow acceleration
        $this->tinker_serv->setVelocity($this->serv_red, 0); // Full speed
        // green
        $this->tinker_serv->setDegree($this->serv_green, 0, 0);
        $this->tinker_serv->setPulseWidth($this->serv_green, 1000, 2000);
        $this->tinker_serv->setPeriod($this->serv_green, 1);
        $this->tinker_serv->setAcceleration($this->serv_green, 0); // Slow acceleration
        $this->tinker_serv->setVelocity($this->serv_green, 0); // Full speed
        $this->tinker_serv->setPosition($this->serv_blue, 0); // Set to most right position
        $this->tinker_serv->enable($this->serv_blue);
        $this->tinker_serv->setPosition($this->serv_red, 0); // Set to most right position
        $this->tinker_serv->enable($this->serv_red);
        $this->tinker_serv->setPosition($this->serv_green, 0);
        $this->tinker_serv->enable($this->serv_green);
$this->tinker_conn->disconnect();
Das ganze innerhalb einer Klasse.
Was sollte passieren?
Rot sollte leuchten.
Was passiert?
Nichts. Bzw keine Änderung. Alle 3 Farben leuchten.
Entweder ich habe die API oder den Servo nicht richtig verstanden.
Ich denke, dass ich Geschwindigkeit, Beschleunigung und Winkel nicht brauche, da ich ja keinen Motor habe.
Also stelle ich nur eine Periode ein um die Helligkeit festzulegen. Richtig?
Hier nochmal die Stati nach dem Aufruf
Array
    [temp] => 436
    [overAllCurr] => 0
    [outV] => 9000
    [stackInV] => 0
    [extV] => 12029
RED
Array
    [acc] => 0
    [vel] => 0
    [per] => 1
    [puls] => Array
            [min] => 1000
            [max] => 2000
    [degr] => Array
            [min] => 0
            [max] => 0
    [pos] => 0
    [on] => 1
BLUE
Array
    [acc] => 0
    [vel] => 0
    [per] => 1
    [puls] => Array
            [min] => 1000
            [max] => 2000
    [degr] => Array
            [min] => 0
            [max] => 0
    [pos] => 0
    [on] => 1
GREEN
Array
    [acc] => 0
    [vel] => 0
    [per] => 1
    [puls] => Array
            [min] => 1000
            [max] => 2000
    [degr] => Array
            [min] => 0
            [max] => 0
    [pos] => 0
    [on] => 1
Vielen Dank schon mal für Eure Hilfe!
MRonline
Dass heißt, dein PHP Programm tut nicht exakt das was brickv tut. Du musst also nur herausbekommen was der Unterschied zwischen den beiden ist.
Dazu könntest du folgendes tun: Den Servo Brick in brickv so einstellen, dass es funktioniert und dann die komplette Konfiguration einmal in PHP auslesen und mit dem vergleichen was dein Programm einstellt. Irgendwo muss da ja ein Unterschied sein.
Nachtrag:
Hast du mal kontrolliert, dass du die richtige UID für den Servo Brick verwendest?
Ich glaub ich hab mich zu ungenau ausgedrückt.
Die Werte sind exakt so, wie im BrickV.
Die Verbindung steht auch, denn ich kann alle Daten des Servos auslesen. Diese (alle Rückgaben der Getter der ServoKlasse) habe ich in Arrays geworfen und ausgegeben (siehe Ende des 1. Posts).
Es scheint aber, als würde der Servo die Daten nicht übernehmen, da keine Änderung sichtbar ist.
Beim anpassen der Werte im BrickV werden die Werte manchmal auch nicht übernommen, dann muss ich den Servo deaktivieren und wieder aktivieren. Das ist aber relativ selten der Fall.
Ich kann auch gern die komplette Klasse posten, aber der betreffende Code ist oben zu sehen.
Vielleicht lässt sich das Problem leichter finden, wenn du mal die Einstellungen im BrickV als Screenshot an einen Beitrag anhängst.
gern.
Im Anhang der, der "Rot" ansteuert.
Grün und Blau genauso, nur Periode auf 1, sodass nur rot leuchtet.
Grüße
Okay, wenn du also den Servo Brick über brickv einstellst, dann leuchten die LEDs so wie sie sollen. Wenn du aber die gleichen Einstellungen über dein PHP Programm machst dann funktioniert es nicht.
Ich gebe dir recht, dein PHP Programm setzt alles so wie es auch in deinem brickv Screenshot eingestellt ist. Das sollte also funktionieren.
Du sagst, manchmal werden auch Einstellungen aus brickv nicht übernommen. Wie ist den die Verbindung zwischen deinem Programm und dem Servo Brick. Ist der einfach per USB angeschlossen? Vielleicht gehen da Aufrufe verloren, weil die Verbindung instabil ist.
Aktivier mal ResponseExpected für alle Funktionen, dann sendet der Brick für alle Funktionsaufrufe auch eine Antwort und die PHP Bindings können feststellen, ob diese auch beim Brick angekommen sind. Etwa hier:
$this->tinker_serv = new Tinkerforge\BrickServo(tfUID_SERVO, $this->tinker_conn);
$this->tinker_serv->setResponseExpectedAll(True);
Wenn dann ein Aufruf verloren geht, wird dir das per Exception mitgeteilt.
ich hab das Gefühl, wir kommen der Lösung näher. Danke schon mal  ;)
Ich habe den Code eingefügt, ohne Ergbnis.
Angeschlossen ist der Stapel (Master mit Servo drauf) wiefolgt:
- Per USB am Raspberry Pi
Der BrickV läuft auf einem Win7 PC, der im gleichen LAN läuft.
Das PHP Script habe ich sowohl auf jedem Win-PC als auch auf dem Raspberry direkt getestet.
Die Firmware der Bricks und Bricklets ist auch die aktuelle.
Hier nochmal eine etwas besser formatierte Ausgabe (alles Getter()), nach dem setzen der Werte:
Array
    [temperature] => 454
    [overAllCurr] => 0
    [outputV] => 9000
    [stackInV] => 0
    [externInV] => 12073
ROT
Array
    [Acceleration] => 0
    [Velocity] => 0
    [Period] => 1
    [PulsWidth] => Array
            [min] => 1000
            [max] => 2000
    [Degree] => Array
            [min] => 0
            [max] => 0
    [Position] => 0
    [Enabled] => 1
GRÜN
Array
    [Acceleration] => 0
    [Velocity] => 0
    [Period] => 1
            [min] => 1000
            [max] => 2000
    [Degree] => Array
            [min] => 0
            [max] => 0
    [Position] => 0
    [Enabled] => 1
BLAU
Array
    [Acceleration] => 0
    [Velocity] => 0
    [Period] => 1
            [min] => 1000
            [max] => 2000
    [Degree] => Array
            [min] => 0
            [max] => 0
    [Position] => 0
    [Enabled] => 1
d.h. es wird überall die Periode 1 zurück gegeben.
der LED Streifen leuchtet aber weiß, d.h. die Periode müsste min >100 sein, pro Servo. Wenn ich im BrickV 1 einstelle, leuchten die LEDs nicht, was ja auch gut so ist  :D
Ich versteh es nicht
hier nochmal die komplette Klasse, falls es hilft:
<?php
require_once PATH_INC."main.inc.php";
* @author MR
class Led_Inc extends Main_Inc {
    private $common;
     * @var IPConnection
    private $tinker_conn;
     * @var BrickServo
    private $tinker_serv;
    private $color_new;
    static private $s_red = array(
        'id'       => 4,
        'min_p'    => 1,
        'max_p'    => 500
    static private $s_green = array(
        'id'       => 5,
        'min_p'    => 1,
        'max_p'    => 8400
    static private $s_blue = array(
        'id'       => 6,
        'min_p'    => 1,
        'max_p'    => 5000
    public function __construct(){
        parent::__construct();
        Main_Class::include_db('common','common.db');
        $this->common = new Common_DB();
        $this->DATA =& parent::$DATA['led'];
        $this->DATA['error'] = '';
        $this->DATA['state'] = 0;
        Main_Class::include_utils('Tinkerforge/IPConnection');
        Main_Class::include_utils('Tinkerforge/BrickServo');
        try {
            $this->set_color();
            $this->set_data();
            $this->get_data();
            Main_Class::include_design('led','led.design');
        } catch (Exception $exc) {
            echo $exc->getTraceAsString();
    public function __destruct() {
        if( $this->tinker_conn->getConnectionState() )
    protected function set_color(){
        if( $_REQUEST['rgb'] && substr($_REQUEST['rgb'], 0, 3)=='rgb' ){
            $rgb_str = substr($_REQUEST['rgb'], 4);
            $rgb_str = substr($rgb_str, 0, strlen($rgb_str)-1);
            $arrRGB = explode(',', $rgb_str);
            if( isset($arrRGB[0]) && isset($arrRGB[1]) && isset($arrRGB[2])){
                $this->color_new['red'] = $arrRGB[0];
                $this->color_new['green'] = $arrRGB[1];
                $this->color_new['blue'] = $arrRGB[2];
                $this->DATA['newRGB'] = $this->color_new;
    protected function set_data(){
        // Configure two servos with voltage 5.5V
        // Servo 1: Connected to port 0, period of 19.5ms, pulse width of 1 to 2ms
        //          and operating angle -100 to 100°
        // Servo 2: Connected to port 5, period of 20ms, pulse width of 0.95
        //          to 1.95ms and operating angle -90 to 90°
        // blue
        $this->tinker_serv->setDegree($this->s_blue['id'], 0, 0);
        $this->tinker_serv->setVelocity($this->s_blue['id'], 0); // Full speed
        $this->tinker_serv->setAcceleration($this->s_blue['id'], 0); // Slow acceleration
        $this->tinker_serv->setPulseWidth($this->s_blue['id'], 1000, 2000);
        $this->tinker_serv->setPeriod($this->s_blue['id'], 1);
        // red
        $this->tinker_serv->setDegree($this->s_red['id'], 0, 0);
        $this->tinker_serv->setVelocity($this->s_red['id'], 0); // Full speed
        $this->tinker_serv->setAcceleration($this->s_red['id'], 0); // Slow acceleration
        $this->tinker_serv->setPulseWidth($this->s_red['id'], 1000, 2000);
        $this->tinker_serv->setPeriod($this->s_red['id'], 7000);
        // green
        $this->tinker_serv->setDegree($this->s_green['id'], 0, 0);
        $this->tinker_serv->setVelocity($this->s_green['id'], 0); // Full speed
        $this->tinker_serv->setAcceleration($this->s_green['id'], 0); // Slow acceleration
        $this->tinker_serv->setPulseWidth($this->s_green['id'], 1000, 2000);
        $this->tinker_serv->setPeriod($this->s_green['id'], 1);
        // setPostion and enable
        $this->tinker_serv->setPosition($this->s_blue['id'], 0); // Set to most right position
        $this->tinker_serv->enable($this->s_blue['id']);
        $this->tinker_serv->setPosition($this->s_red['id'], 0); // Set to most right position
        $this->tinker_serv->enable($this->s_red['id']);
        $this->tinker_serv->setPosition($this->s_green['id'], 0);
        $this->tinker_serv->enable($this->s_green['id']);
    protected function get_data(){
        $arrSred['temperature'] = $this->tinker_serv->getChipTemperature();
        $arrSred['overAllCurr'] = $this->tinker_serv->getOverallCurrent();
        $arrSred['outputV'] = $this->tinker_serv->getOutputVoltage();
        $arrSred['stackInV'] = $this->tinker_serv->getStackInputVoltage();
        $arrSred['externInV'] = $this->tinker_serv->getExternalInputVoltage();
        $this->DATA['general'] = $arrSred;
        unset($arrSred);
        #echo 'RED';
        $arrSred['Acceleration'] = $this->tinker_serv->getAcceleration($this->s_red['id']);
        $arrSred['Velocity'] = $this->tinker_serv->getVelocity($this->s_red['id']);
        $arrSred['Period'] = $this->tinker_serv->getPeriod($this->s_red['id']);
        $arrSred['PulsWidth'] = $this->tinker_serv->getPulseWidth($this->s_red['id']);
        $arrSred['Degree'] = $this->tinker_serv->getDegree($this->s_red['id']);
        $arrSred['Position'] = $this->tinker_serv->getPosition($this->s_red['id']);
        $arrSred['Enabled'] = $this->tinker_serv->isEnabled($this->s_red['id']);
        $this->DATA['red'] = $arrSred;
        unset($arrSred);
        #echo 'BLUE';
        $arrSred['Acceleration'] = $this->tinker_serv->getAcceleration($this->s_blue['id']);
        $arrSred['Velocity'] = $this->tinker_serv->getVelocity($this->s_blue['id']);
        $arrSred['Period'] = $this->tinker_serv->getPeriod($this->s_blue['id']);
        $arrSred['PulsWidth'] = $this->tinker_serv->getPulseWidth($this->s_blue['id']);
        $arrSred['Degree'] = $this->tinker_serv->getDegree($this->s_blue['id']);
        $arrSred['Position'] = $this->tinker_serv->getPosition($this->s_blue['id']);
        $arrSred['Enabled'] = $this->tinker_serv->isEnabled($this->s_blue['id']);
        $this->DATA['blue'] = $arrSred;
        unset($arrSred);
        #echo 'GREEN';
        $arrSred['Acceleration'] = $this->tinker_serv->getAcceleration($this->s_green['id']);
        $arrSred['Velocity'] = $this->tinker_serv->getVelocity($this->s_green['id']);
        $arrSred['Period'] = $this->tinker_serv->getPeriod($this->s_green['id']);
        $arrSred['PulsWidth'] = $this->tinker_serv->getPulseWidth($this->s_green['id']);
        $arrSred['Degree'] = $this->tinker_serv->getDegree($this->s_green['id']);
        $arrSred['Position'] = $this->tinker_serv->getPosition($this->s_green['id']);
        $arrSred['Enabled'] = $this->tinker_serv->isEnabled($this->s_green['id']);
        $this->DATA['green'] = $arrSred;
new Led_Inc();
die set_color() hat zZ keine Auswirkung!
Okay, wir haben das hier mal nachgebaut und können dein Problem so nicht nachstellen. Was aber auffällt ist, dass du eine ungewöhnliche Weise verwendest um das PWM Signal einzustellen. Da scheint noch ein Problem im Servo Brick zu sein, dass im normalen Betrieb mit Servos aber nicht auftritt. Bei Änderung der Period werden nicht alle abhängigen Werte richtig neu berechnet. Das macht im Betrieb mit Servos wie gesagt kein Problem, da die Period hier fest ist. Du verwendest sie aber als den aktiven Stellwert.
Ich schlage daher folgende alternative Vorgehensweise vor, die mehr der normalen Arbeitsweise des Servo Bricks entspricht:
Pulse Width: 0 bis 20000
Degree: 0 bis 100
Velocitiy und Acceleration: 65535
Period: 20000
Jetzt kannst du über die Position zwischen 0 und 100 den High-Anteil des PWM Signals einstellen.
Vielen Dank!!!
Es funktioniert  :D
Nun muss ich nur noch ein paar Anpassungen der Werte vornehmen, um die Helligkeitsunterschiede der verschiedenen Farben auszugleichen und dann kann sich das sehen lassen :)
Danke!
Hallo MRonline,
ich finde es spannend was du da machst.
Hast du Lust einen Wiki-Eintrag dafür zu machen?
Ich könnte mir vorstellen, dass andere das auch interessant finden.
Viele Grüße,
Nemo
Gern!
Ich melde mich, wenn mein Aufbau optimiert ist und wie gewünscht läuft.
Zur Zeit ist es ja noch Bastel-Status  ;D
