Tinkerforge_ipConnection fail
Ja meine lieben.
Ich habe for kurzter zeit eine illusion gehapt das ich ENDLICH das raetsel geloest habe. Das ist, die wetter stations functioniert; Drop Box Connection hat endlich geklappt; aber leider das Python script kann nicht die connection mit tinkerforge_ip connection fertig bringen.
Es waerde sehr schoen wenn jemand von den Tinkerforge Kunden wissen was falsch ist. Das script habe ich nicht selber geschrieben, Gott sei dank, aber habe vom Internet abgeladen. http://tinyurl.com/mxw8omx heisst Main.py und upload.py
Es schtolpert immer bei dem "tinkerforge.ip_connection.
Hiermit die "Error message"
live and kicking'
  File "main.py", line 111, in <module>
    main()
  File "main.py", line 91, in main
    light_level=light_sensor.get_illuminance()/10.0
  File "/usr/local/lib/python2.7/dist-packages/tinkerforge.egg/tinkerforge/bricklet_ambient_light.py", line 103, in get_illuminance
  File "/usr/local/lib/python2.7/dist-packages/tinkerforge.egg/tinkerforge/ip_connection.py", line 878, in send_request
tinkerforge.ip_connection.Error: -1: Did not receive response for function 1 in time
Exception in thread Disconnect-Prober (most likely raised during interpreter shutdown):Exception in thread Brickd-Receiver (most likely raised during interpreter shutdown):
  File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner
  File "/usr/lib/python2.7/threading.py", line 505, in runTraceback (most recent call last):
  File "/usr/local/lib/python2.7/dist-packages/tinkerforge.egg/tinkerforge/ip_connection.py", line 617, in receive_loop  File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner
<type 'exceptions.TypeError'>: 'NoneType' object is not callable
  File "/usr/local/lib/python2.7/dist-packages/tinkerforge.egg/tinkerforge/ip_connection.py", line 752, in disconnect_probe_loop
  File "/usr/lib/python2.7/Queue.py", line 174, in get
Hoffentlich gibts jemand der weiss was da los ist?
Vieln Dank
Karl
Ja alle Bricklets sehe ich im Brickview. Die bricklet addressen habe ich natuerlich umgeandert.Master ist 6xftxf,licht ist mbr,Temp ist dY7 Baro ist k4s and Humidity ist keV. Aber das script hat ja die Humidity nicht drinnen. Ich habe gedacht bestens warten bis ich es erstmal functioniert, before ich probiere die Humidity reingeben. Ich weiss ja nicht was der richtige Syntax ist.
Danke fuer die antwort.
Habe den fehler schon gefunden. Mea culpa mea culpa mea maxima culpa. Hast schon recht gehabt Borg. Die UID ist mbR und ich habe mbr reingetan. Wie kann man so bloed sein!! Aber ich wuerde sehr dankbar sein fuer den richtigen syntax fuer die Humidity bricklet.
Karl
