Hello there,
the callback functionality of the SoundIntensity Bricklet will only fire if the measured value has changed. Thus I will not get measurements uniformly distributed over time (to calculate meaning ful averages). Is there a way to get continuous measurements (except maybe by actively querying every so often)?
Thanks in advance.
Best,
Martin
You can set the frequency of your measurements with set_debounce_period and then use the CALLBACK_INTENSITY_REACHED by setting an intensity threshold (set_intensity_callback_threshold) of something like "smaller than 4095", so it is always active.
