RED-Brick Updatefehler
sobald ich ein update auf dem Redbrick durchführe gibt es die Fehlermeldung, unschön wie kann ich das Problem beheben.
tf@red-brick:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
libpam-systemd : Depends: systemd (= 215-17+deb8u6) but 215-17+deb8u3 is installed
perl : Depends: perl-base (= 5.20.2-3+deb8u3) but 5.20.2-3+deb8u6 is installed
        Recommends: rename but it is not installed
systemd : Depends: libsystemd0 (= 215-17+deb8u3) but 215-17+deb8u6 is installed
E: Unmet dependencies. Try using -f.
