IMU Brick 2.0 get position
Hello everybody,
I'm trying to implement a code (Python) to get position x y z from IMU Brick 2.0 accelerometer, in live mode.
In the first step, I implemented the rotate accelerometer by quaternion to remove the gravity and rotation of my sensor.
After i integrate directly to have velocity and position :
example :
Vx(k) = Vx(k-1)+Ax(k)*dt
X(k) = X(k-1) + Vx(k)*dt
Nevertheless, into my accel. data I have an offset.
Somebody would have already implemented this type of code to remove the offset (drift) ? to get the position
I don't know if i must a kalman filter or other....
Thank you
Hello JPannetier,
I wanted to do the same a while back and did some research and I want to help not wasting time on this. To sum things up: you can't get good position information over time by only using an IMU. This topic is called Dead reckoning (https://en.wikipedia.org/wiki/Dead_reckoning) and is way harder to get running as it seems to be at first sight.
A lot of people had this idea and ended up using something different. See here for reference:
The problem is noise and precision of measurement when using acceleration or velocity data over time for estimating a position. To get a grasp of the topic I can recommend watching this video (the starting position marks the explanation of why your double integration leads to a drift):
In fact VR-headsets use sensor fusion by combining their IMU data (gyroscope and accelerometer) with their optical IR-light-based marker positions (also called pose estimation). I can recommend a very good talk by Philipp Zabel about HMD tracking systems (german language but images and animations should give you some impressions) and some related videos on youtube:
So what you could do is to:
  • Add internal sensors which track the current position with markers, by scanning a known environment with markerless tracking algorithms or by using systems like GPS
  • Add external sensors which track the position and orientation of your system and use it to recalibrate your IMU data with at least more than 30 Hz
  • Use position sensors which will inevitably affect the shape and size of your system (https://en.wikipedia.org/wiki/Position_sensor)
Hope this helps :)
Regards,
Philipp
