Geschrieben January 27, 2019 at 18:1627. Jan 2019 Hi, I just got a new IO-16 Bricklet 2.0 (https://www.tinkerforge.com/de/doc/Hardware/Bricklets/IO16_V2.html) but this is not detected in my OpenHab (running on Raspberry) my old IO-16 Bricklet (https://www.tinkerforge.com/de/doc/Hardware/Bricklets/IO16.html) work great. I had a short look into the sources and could see that the new bricklet is not yet integrated. Are these your sources or is someone else supporting the tinkerforge binding (https://www.openhab.org/addons/bindings/tinkerforge1/) for you? Thanks.
Geschrieben January 27, 2019 at 22:2927. Jan 2019 Hi MiRo, I'm the author of the openHAB Tinkerforge Binding. I'm a member of the openHAB community and not employed by TF. Currently the binding is getting a full rewrite as openHAB2 binding. The V2 Bricklets will only be supported with this new binding. The binding is work in progress and will need some more weeks to get an alpha release. I'm regularly publishing development snapshots for everyone who wants to test it and hopefully give some feedback. At the moment none of the IO-16 Bricklets are supported. But as soon as they are in I would appreciate your feedback. There is a thread in the german forum, where I'm regularly posting about the progress: https://www.tinkerunity.org/forum/index.php/topic,1769.360.html Maybe you can read this using a translator? If this is not a feasible way and your really interested in the progress of the development I could start a similar thread in the english forum. Regards, Theo
Geschrieben February 7, 2019 at 16:587. Feb 2019 Autor Hallo Theo, kein Problem - ich kann auch Deutsch . Danke für die Antwort. Ich schau mir Deinen Thread einfach mal an, und probiere Dein neues Binding aus.
