in the process od switching from MQTT proxy 1.0 to 2.0.
Question: how to subscribe to topic changes?
Started as follows:
Raspberry Pi 4 with Master Brick and RGB LED 2.0 Bricklet
Installed mosquitto
Installed the MQTT bindings in /usr/local/bin.
Started the script: tinkerforge_mqtt --debug
Log:
2019-09-06 10:57:03,889 <DEBUG> MQTT bindings: Configuring connection to MQTT broker at localhost:1883
2019-09-06 10:57:03,890 <DEBUG> MQTT bindings: Connected to MQTT broker at localhost:1883
2019-09-06 10:57:03,892 <DEBUG> paho.mqtt.client: Sending CONNECT (u0, p0, wr0, wq0, wf1, c1, k60) client_id=
2019-09-06 10:57:03,893 <DEBUG> paho.mqtt.client: Received CONNACK (0, 0)
2019-09-06 10:57:03,893 <DEBUG> MQTT bindings: Connected to mqtt broker.
2019-09-06 10:57:03,894 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m1) [('tinkerforge/request/#', 0)]
2019-09-06 10:57:03,894 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m2) [('tinkerforge/register/#', 0)]
2019-09-06 10:57:03,895 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m3), 'tinkerforge/callback/bindings/restart', ... (4 bytes)
2019-09-06 10:57:03,895 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m4) [('tinkerforge/callback/bindings/restart', 0)]
2019-09-06 10:57:03,896 <DEBUG> MQTT bindings: Connecting to brickd at localhost:4223
2019-09-06 10:57:03,897 <DEBUG> paho.mqtt.client: Received SUBACK
2019-09-06 10:57:03,899 <DEBUG> paho.mqtt.client: Received SUBACK
Published from terminal to set the color of a RGB LED V2 bricklet:
mosquitto_pub -t tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value -m '{"r": 0, "g": 0, "b": 200}'
Log:
2019-09-06 10:57:51,513 <DEBUG> paho.mqtt.client: Received PUBLISH (d0, q0, r0, m0), 'tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value', ...  (29 bytes)
2019-09-06 10:57:51,514 <DEBUG> MQTT bindings:
2019-09-06 10:57:51,515 <DEBUG> MQTT bindings: Calling function set_rgb_value for device Jng of type rgb_led_v2_bricklet.
2019-09-06 10:57:51,516 <ERROR> MQTT bindings: ubyte format requires 0 <= number <= 255 (call of set_rgb_value of rgb_led_v2_bricklet Jng)
2019-09-06 10:57:51,517 <DEBUG> MQTT bindings: Calling function set_rgb_value for device Jng of type rgb_led_v2_bricklet succedded.
2019-09-06 10:57:51,517 <DEBUG> MQTT bindings: Publishing response to tinkerforge/response/rgb_led_v2_bricklet/Jng/set_rgb_value
2019-09-06 10:57:51,518 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m5), 'tinkerforge/response/rgb_led_v2_bricklet/Jng/set_rgb_value', ... (2 bytes)
2019-09-06 10:57:51,518 <DEBUG> MQTT bindings:
2019-09-06 10:58:51,597 <DEBUG> paho.mqtt.client: Sending PINGREQ
2019-09-06 10:58:51,598 <DEBUG> paho.mqtt.client: Received PINGRESP
The color of the RGB LED 2.0 Bricklet changed.
Note: on the brick viewer had to refresh tab RGB LED 2.0 to get the new values.
Subscribing to get_rgb_value from terminal:
mosquitto_sub -v -t tinkerforge/request/rgb_led_v2_bricklet/Jng/get_rgb_value
Changed the color via Brick Viewer to RED (255,0,0).
Nothing happens on the terminal.
Changed the command to:
mosquitto_sub -t tinkerforge/request/rgb_led_v2_bricklet/Jng/get_rgb_value
Question:
How to subscribe to value changes?
Would like to use this in Node-RED.
You have to subscribe to the
[...]/response/[...]
topic, instead of the
[...]/request/[...]
topic. So in your case
mosquitto_sub  -t tinkerforge/response/rgb_led_v2_bricklet/Jng/get_rgb_value
If you then run
mosquitto_pub -t tinkerforge/request/rgb_led_v2_bricklet/Jng/get_rgb_value -m ''
in another shell, you will see the color.
For debugging purposes, you can start the bindings with
The response paths are then printed to standard out. Also you can subscribe to
tinkerforge/#
to see all traffic.
Thanks for help.
Using mosquito for this test is ok:
Terminal 1 subscribing to all topics:
mosquitto_sub  -t tinkerforge/#
Terminal 2 setting the color:
mosquitto_pub -t tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value -m '{"r":0, "g":0, "b":123}'
Terminal 1 shows:
Next step is to obtain the same in Node-RED.
Defined a simple flow.
mqtt in node with topic tinkerforge/# and broker localhost port 1883.
The mqtt in node outputs to a debug node.
When changing the color via terminal, then the debug node shows:
06/09/2019, 14:15:01node: DEBUG TF ALL
tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value : msg.payload : string[23]
"{"r":0, "g":0, "b":123}"
Now, to test changing the color via mqtt out node (and debug node) using a function node:
//Example to set a green color = RGB (0, 255, 0)
  var r = 0;
  var g = 255;
  var b = 0;
  //Mosquitto Command:
  //mosquitto_pub -t tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value -m '{"r":255, "g":0, "b":0}'
  //Translated to JavaScript Message with Topic and Payload
  var msgmqtt = {topic: "tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value", payload:{"r":r,"g":g,"b":b} };
  return msgmqtt;
The debug node shows:
06/09/2019, 14:16:30node: 65847a3b.80f134
tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value : msg.payload : Object
{ r: 0, g: 255, b: 0 }
BUT the color is not changed.
Any hint what is missing in this setup?
Can you post the output of
and the debug output from the bindings for both cases? (Changing the color via the terminal and with a MQTT out node)
Also, the debug node outputs differ: If you use the terminal, the payload is a string, with the node, it is an object. Maybe you have to convert the JSON object to a string before publishing it?
Yes, noted the difference in string and json from mqtt out.
To note is that this node-red example setup has been used without issues using mqtt proxy v1.0.
Tried to a JSON node, but again no change.
Tried a string, i.e. "R",... but also no change.
Output of mosquitto_sub -t tinkerforge/#
Debug
pi@4dev:~ $ tinkerforge_mqtt --debug
2019-09-06 14:51:22,144 <DEBUG> MQTT bindings: Configuring connection to MQTT broker at localhost:1883
2019-09-06 14:51:22,145 <DEBUG> MQTT bindings: Connected to MQTT broker at localhost:1883
2019-09-06 14:51:22,147 <DEBUG> paho.mqtt.client: Sending CONNECT (u0, p0, wr0, wq0, wf1, c1, k60) client_id=
2019-09-06 14:51:22,148 <DEBUG> paho.mqtt.client: Received CONNACK (0, 0)
2019-09-06 14:51:22,148 <DEBUG> MQTT bindings: Connected to mqtt broker.
2019-09-06 14:51:22,148 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m1) [('tinkerforge/request/#', 0)]
2019-09-06 14:51:22,149 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m2) [('tinkerforge/register/#', 0)]
2019-09-06 14:51:22,149 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m3), 'tinkerforge/callback/bindings/restart', ... (4 bytes)
2019-09-06 14:51:22,149 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m4) [('tinkerforge/callback/bindings/restart', 0)]
2019-09-06 14:51:22,150 <DEBUG> MQTT bindings: Connecting to brickd at localhost:4223
2019-09-06 14:51:22,152 <DEBUG> paho.mqtt.client: Received SUBACK
2019-09-06 14:51:22,153 <DEBUG> MQTT bindings: Connected to Brick Daemon: Connection established after request from user.
2019-09-06 14:51:22,153 <DEBUG> MQTT bindings: Connected to brickd at localhost:4223
2019-09-06 14:51:22,153 <DEBUG> paho.mqtt.client: Received SUBACK
2019-09-06 14:51:22,198 <DEBUG> paho.mqtt.client: Received SUBACK
2019-09-06 14:51:28,094 <DEBUG> paho.mqtt.client: Received PUBLISH (d0, q0, r0, m0), 'tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value', ...  (23 bytes)
2019-09-06 14:51:28,094 <DEBUG> MQTT bindings:
2019-09-06 14:51:28,095 <DEBUG> MQTT bindings: Calling function set_rgb_value for device Jng of type rgb_led_v2_bricklet.
2019-09-06 14:51:28,096 <DEBUG> MQTT bindings: Calling function set_rgb_value for device Jng of type rgb_led_v2_bricklet succedded.
Node-RED MQTT out node
In the terminal no entry subscribing tinkerforge/#
In debug
2019-09-06 14:53:50,026 <DEBUG> MQTT bindings: Configuring connection to MQTT broker at localhost:1883
2019-09-06 14:53:50,026 <DEBUG> MQTT bindings: Connected to MQTT broker at localhost:1883
2019-09-06 14:53:50,028 <DEBUG> paho.mqtt.client: Sending CONNECT (u0, p0, wr0, wq0, wf1, c1, k60) client_id=
2019-09-06 14:53:50,029 <DEBUG> paho.mqtt.client: Received CONNACK (0, 0)
2019-09-06 14:53:50,029 <DEBUG> MQTT bindings: Connected to mqtt broker.
2019-09-06 14:53:50,030 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m1) [('tinkerforge/request/#', 0)]
2019-09-06 14:53:50,030 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m2) [('tinkerforge/register/#', 0)]
2019-09-06 14:53:50,030 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m3), 'tinkerforge/callback/bindings/restart', ... (4 bytes)
2019-09-06 14:53:50,031 <DEBUG> paho.mqtt.client: Sending SUBSCRIBE (d0, m4) [('tinkerforge/callback/bindings/restart', 0)]
2019-09-06 14:53:50,031 <DEBUG> MQTT bindings: Connecting to brickd at localhost:4223
2019-09-06 14:53:50,032 <DEBUG> paho.mqtt.client: Received SUBACK
2019-09-06 14:53:50,033 <DEBUG> paho.mqtt.client: Received SUBACK
2019-09-06 14:53:50,034 <DEBUG> MQTT bindings: Connected to Brick Daemon: Connection established after request from user.
2019-09-06 14:53:50,034 <DEBUG> MQTT bindings: Connected to brickd at localhost:4223
2019-09-06 14:53:50,078 <DEBUG> paho.mqtt.client: Received SUBACK
It seems like the MQTT out node sends either to the wrong topic or to the wrong broker. Can you try again, but with
mosquitto_sub -v -t '#'
instead of
mosquitto_sub -v -t 'tinkerforge/#'
This will print everything published to the broker.
That was a great hint.
The log showed no topic, only payload, means error in node-red creating topic.
The log: first line using terminal, second via node-red.
tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value {"r":255,"g":0,"b":0}
Changed the node-red function node creating topic with payload
var r = 0;
var g = 255;
var b = 0;
//mosquitto_pub -t tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value -m '{"r":0, "g":255, "b":0}'
msg.topic = "tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value";
msg.payload = {"r":r,"g":g,"b":b};
return msg;
resulting in log:
tinkerforge/request/rgb_led_v2_bricklet/Jng/set_rgb_value {"r":0,"g":255,"b":0}
That was good learning = again thanks for help.
For those interested, based on previous learning's, created an Indoor Air Quality  Node-RED Dashboard using MQTT.
Please find on GitHub.
