MQTT IO-4 v2 Input No Message
using Node-RED - trying to MQTT listen to input state changes of an IO-4 v2 bricklet having a push-button connected to channel 1 configured as input pull-up.
Issue: When pushing the button, no MQTT message is received - see 2).
Tested first in the Brick Viewer 2.4.11 and the value changes for channel from low to high when pressing the push-button.
Node-RED Nodes Configuration
1) mqtt in with topic tinkerforge/#. Messages are received (see below test channel 0 as output)
Tested OK (MQTT message received) the IO-4 state change of channel 0 (output) - led connected - using in a function node with msg.payload input true or false
//Bricklet: IO-4 - Example to set pin 0 high | low
var brickletUID = "G4d";
var topicPrefix = "tinkerforge/request/io4_v2_bricklet/";
var topicSuffix = "/set_configuration";
msg.topic = topicPrefix+brickletUID+topicSuffix;
msg.payload = {"channel": 0, "direction": "out", "value": msg.payload};
node.status({text:"State:"+msg.payload.value});
return msg;
2) Channel 1 as Input with a push-button connected.
Configured a function node as follows - no MQTT message received when pushing the button
//IO-4 - example set callback configuration
var topicPrefixRequest = "tinkerforge/request/io4_v2_bricklet/";
var topicPrefixRegister = "tinkerforge/register/io4_v2_bricklet/";
msg.topic = topicPrefixRequest+brickletUID+"/set_configuration";
msg.payload = {"channel": 1, "direction": "i", "value":true};
node.send(msg);
msg.topic = topicPrefixRequest+brickletUID+"/set_all_input_value_callback_configuration";
msg.payload = {"period": 0, "value_has_to_change": true};
node.send(msg);
msg.topic = topicPrefixRegister+brickletUID+"/all_input_value";
msg.payload = {"register":true};
node.send(msg);
msg.topic = topicPrefixRequest+brickletUID+"/get_configuration";
msg.payload = {"channel":1};
node.send(msg);
What is wrong in the configuration?
node.send(msg);
A period of 0 disables the callback, you have to set it to (at least) 1.
Got it - overlooked the documentation "A value of 0 turns the callback off." = got mis leaded by the default value 0 (period – Type: int, Unit: 1 ms, Range: [0 to 232 - 1], Default: 0).
After changing, its working fine.
Thanks for the swift help.
