Geschrieben May 26, 2020 at 11:1626. Mai 2020 Does the Outdoor Weather Station Wind Direction Sensor need to be calibrated to account for the orientation of the hardware when it has been installed?
Geschrieben May 26, 2020 at 12:1826. Mai 2020 The sensor operates mechanical and the station does not have any facility to calibrate for non-horizontal orientation, so you must install the station as horizontal as possible. On top of the rain fall sensor, there is a small bubble level that can help you orient the station.
Geschrieben May 26, 2020 at 12:5826. Mai 2020 In case you mean the orientation of the cardinal directions: The Outdoor Weather Bricklet does not support remapping the directions (i.e. north, east, south, west -> east, south, west, north).
Geschrieben May 29, 2020 at 09:0729. Mai 2020 Autor Thanks rtrbt for your replies. I am sorry, I didn't make my question clear enough. I was asking whether the sensor has the ability to measure the true cardinal direction (and therefore must have an inbuilt compass or some sort) or whether I have to make a correction in my data collection program to take account of the installed orientation of the hardware.
Geschrieben May 29, 2020 at 14:1929. Mai 2020 Hi, You have to correct this in your program, the outdoor weather station can't correct this itself.
Geschrieben June 6, 2023 at 15:306. Jun 2023 Hello could someone tell me in which direction I have to direct the wind sensor? My weatherstation is already installed and I need to program an offset since I am not able to change the sensor direction anymore. thanks
