[Java 2.0.1 binding] TimeOutException name collision
In the 2.0.1 Java bindings (and maybe before, don't know), we have two public TimeOutException classes:
com.tinkerforge.TimeoutException
and
com.tinkerforge.IPConnection.TimeOutException
If your program requires both (as is typically the case), then Java requires you to fully qualify both class names so that the compiler can differentiate the two.
This is pretty awkward. Historically, Java APIs have tried to avoid such name collisions.
Renaming the simple name of one, or both, would solve this.
It was com.tinkerforge.IPConnection.TimeoutException in bindings version 1.x.y. I moved the TimeoutException to com.tinkerforge.TimeoutException in version 2.0.0, but missed to remove it from com.tinkerforge.IPConnection. The inner version of TimeoutException is not used anymore in the bindings and I just remove it in version 2.0.2.
You only need com.tinkerforge.TimeoutException in your program. Sorry for this oversight.
On the subject of exceptions, maybe you should create a hierarchy rooted in TinkerForgeException. Having an exception hierarchy allows you (and clients) to specify much shorter throws clauses or catch blocks. The same approach is used by lots of APIs throwing IOException and SQLException. Both of these have many different sub-exceptions, but clients are not obliged to specify them everywhere in their code.
  • 4 weeks later...
