Geschrieben February 8, 2026 at 12:228. Feb 2026 Hallo,ich würde gebeten meine Lösung hier mal kurz zu beschreiben.Ich nutze:2x WARP3 ProCupra Tavascan VZSeat Mii Electric2x WiCAN OBD2-CAN Adapter von MeatPi (WICAN-OBD-C3)Auf einem Ubuntu Server läuft die aktuelle evcc Version und ein Mosquitto Broker.Das WiCAN Modul hat die Firmware v4.12-102-ge1d0a09.Hier die Config vom WiCAN für den Mii:{ "config": { "wifi_mode": "APStation", "ap_ch": "1", "sta_ssid": "XXX", "sta_pass": "XXX", "sta_security": "wpa2", "can_datarate": "500K", "can_mode": "normal", "port_type": "tcp", "port": "3333", "ap_pass": "XXX", "protocol": "auto_pid", "ble_pass": "123456", "ble_status": "disable", "sleep_status": "disable", "sleep_volt": "13.1", "sleep_time": "16", "batt_alert": "disable", "mqtt_en": "enable", "mqtt_url": "mqtt://10.10.10.10", "mqtt_port": "1883", "mqtt_user": "", "mqtt_pass": "", "keep_alive": "30", "mqtt_tx_topic": "wican/tx", "ap_auto_disable": "enable", "mqtt_tx_en": "disable", "mqtt_rx_topic": "wican/rx", "mqtt_rx_en": "disable", "mqtt_status_topic": "mii/status", "mqtt_elm327_log": "disable" }, "auto_pid_car_data": { "cars": [ { "car_model": "Seat Mii", "init": "", "pids": [] } ] }, "auto_pid": { "initialisation": "ATSP6;ATST96;", "grouping": "disable", "autopid_polling": "enable", "group_dest_type": "Default", "destination": "", "cycle": "5000", "car_specific": "disable", "ha_discovery": "disable", "car_model": "Seat Mii", "pids": [ { "Name": "SoC", "Init": "ATSH7E5;ATCRA7ED;", "PID": "22028C", "Expression": "B4/2.4", "MinValue": "0", "MaxValue": "100", "Period": "10000", "Type": "MQTT_WallBox", "Send_to": "mii/soc" }, { "Name": "Range", "Init": "ATSH714;ATCRA77E;", "PID": "2222E0", "Expression": "(B4*256)+B5", "MinValue": "0", "MaxValue": "250", "Period": "10000", "Type": "MQTT_WallBox", "Send_to": "mii/range" }, { "Name": "Odometer", "Init": "ATSH7E5;ATCRA7ED;", "PID": "2202BD", "Expression": "((B6*65536)+(B7*256)+B9)", "MinValue": "", "MaxValue": "", "Period": "10000", "Type": "MQTT_WallBox", "Send_to": "mii/odometer" } ], "std_pids": [], "standard_pids": "enable", "ecu_protocol": "9" } }Hier die Config vom WiCAN für den Tavascan:{ "config": { "wifi_mode": "APStation", "ap_ch": "1", "sta_ssid": "XXX", "sta_pass": "XXX", "sta_security": "wpa2", "can_datarate": "500K", "can_mode": "normal", "port_type": "tcp", "port": "3333", "ap_pass": "XXX", "protocol": "auto_pid", "ble_pass": "123456", "ble_status": "disable", "sleep_status": "disable", "sleep_volt": "13.1", "sleep_time": "16", "batt_alert": "disable", "mqtt_en": "enable", "mqtt_url": "mqtt://10.10.10.10", "mqtt_port": "1883", "mqtt_user": "", "mqtt_pass": "", "keep_alive": "30", "mqtt_tx_topic": "wican/tx", "ap_auto_disable": "enable", "mqtt_tx_en": "disable", "mqtt_rx_topic": "wican/rx", "mqtt_rx_en": "disable", "mqtt_status_topic": "tavascan/status", "mqtt_elm327_log": "disable" }, "auto_pid_car_data": { "cars": [ { "car_model": "VW: ID", "init": "ATST96;ATFCSD300000;ATFCSM1;", "pids": [ { "pid": "22028C1", "pid_init": "ATSP7;ATCP17;ATSHFC007B;ATFCSH17FC007B;ATCRA17FE007B;", "parameters": [ { "name": "SOC", "expression": "B4*0.461-10.64", "unit": "%", "class": "battery", "period": "5000", "min": "0", "max": "10000", "type": "MQTT_WallBox", "send_to": "tavascan/soc" } ] }, { "pid": "222AB62", "pid_init": "ATSP6;ATCP18;ATSH710;ATFCSH710;ATCRA77A;", "parameters": [ { "name": "RANGE", "expression": "(B5*256)+B6", "unit": "km", "class": "distance", "period": "5000", "min": "", "max": "", "type": "MQTT_WallBox", "send_to": "tavascan/range" } ] }, { "pid": "22295A", "pid_init": "ATSP7;ATCP17;ATSHFC0076;ATFCSH17FC0076;ATCRA17FE0076;", "parameters": [ { "name": "ODOMETER", "expression": "[B4:B6]", "unit": "km", "class": "distance", "period": "5000", "min": "0", "max": "", "type": "MQTT_WallBox", "send_to": "tavascan/odometer" } ] } ] } ] }, "auto_pid": { "initialisation": "", "grouping": "disable", "autopid_polling": "enable", "group_dest_type": "Default", "destination": "", "cycle": "5000", "car_specific": "enable", "ha_discovery": "disable", "car_model": "VW: ID", "pids": [], "std_pids": [], "standard_pids": "disable", "ecu_protocol": "6" } }Beim Tavascan gibt es aktuell mit der Firmware und mit den Einstellungen auch keinen Alarm, wenn der PKW abgeschlossen ist...In evcc ist die Konfiguration dann wie folgt, als Benutzerdefiniertes Gerät:title: Seat Mii icon: car capacity: 32 phases: 2 soc: source: mqtt topic: mii/soc range: source: mqtt topic: mii/range odometer: source: mqtt topic: mii/odometer features: - welcomecharge onIdentify: mode: pvUnd gleiches für den Tavascan:title: Cupra Tavascan icon: car capacity: 77 phases: 3 soc: source: mqtt topic: tavascan/soc range: source: mqtt topic: tavascan/range odometer: source: mqtt topic: tavascan/odometer features: - welcomecharge onIdentify: mode: pvAlso der Mosquitto Broker, der auf dem Unbuntu Server läuft, ist der Zentrale Datenaustauschpunkt. Dieser wird sowohl von den Wallboxen, WiCAN Modulen und vom evcc verwendet um die entsprechenden Infos auszutauschen.In evcc ist bei den Wallboxen ein Standard Fahrzeug hinterlegt und das Update Verhalten steht auf "immer", das Update-Intervall auf 1 Minute und das interpolieren ist deaktiviert.In der Garage ist ein Access Point und sobald eines der Autos in diese Reichweite gelangt wird der SoC an den MQTT Broker gesendet, evcc bekommt die Informationen und zeigt diese an. Ist der PKW nicht in Reichweite, dann zeigt evcc nur die zuletzt erhaltenen Werte an.Also das funktioniert hier so wirklich super...Viele GrüßeStefan
Geschrieben February 9, 2026 at 08:389. Feb 2026 Hallo @Raudi welches WiCAN Modul benutz du genau, da es ja scheinbar eine größere Auswahl gibt:
Geschrieben February 9, 2026 at 09:349. Feb 2026 Für den OBD2 Port gibt es nur den WICAN und den WICAN PRO.Der einfache reicht aber für diese Zwecke hier völlig aus.Nutze ihn auch schon seit gut 6 Monaten mit unserem Ioniq um den SOC an EVCC zu senden.Klappt auch hier einwandfrei.@Raudi Was hat das für eine Funktion ?features: - welcomechargeWird damit das Vorwärmen aktiviert, wenn das Kabel steckt ?
Geschrieben February 9, 2026 at 10:089. Feb 2026 Hallo @Ben77 @RaudiIst bekannt ob:Am 9.2.2026 um 10:34 schrieb Ben77: Für den OBD2 Port gibt es nur den WICAN und den WICAN PRO.auch für einen Skoda Elroq Modelljahr 2025/2026 funktioniert?
