PV-Ertragsprognose und Firmware 2.11.0
Hallo und guten Morgen,
habe gestern meine Warp 3 Pro auf Firmware 2.11.0 (von 2.10.3) aktualisiert und seither (zumindest denke ich das) ein Problem mit der PV-Ertragsprognose:
Im Status wird sie gelb angezeigt: "Keine Daten vorhanden"
Im Ereignisprotokoll steht jede halbe Stunde:
2026-06-08 23:44:09,300 | solar_forecast   | HTTP error while downloading solar forecast: 422 - Probably invalid declination/azimuth/power
2026-06-08 23:44:09,312 | solar_forecast   | Next solar forecast API call will be in 30 minutes
2026-06-08 23:44:09,313 | solar_forecast   | HTTP error while downloading solar forecast: 422 - Probably invalid declination/azimuth/power
2026-06-08 23:44:09,324 | solar_forecast   | Next solar forecast API call will be in 30 minutes
Im Debug-Log finde ich:
"solar_forecast/config": {"enable":true,"source":0,"api_url":"https://api.forecast.solar/","cert_id":-1},
 "solar_forecast/state": {"wh_today":-1,"wh_today_remaining":-1,"wh_tomorrow":-1,"rate_limit":-1,"rate_remaining":-1,"next_api_call":29682398},
 "solar_forecast/planes/0/config": {"enable":true,"name":"Garage","lat":null,"long":null,"dec":37,"az":22,"wp":3330},
 "solar_forecast/planes/0/state": {"last_sync":0,"last_check":29682368,"next_check":0,"place":null},
 "solar_forecast/planes/0/forecast": {"first_date":0,"resolution":1,"forecast":[]},
 "solar_forecast/planes/1/config": {"enable":true,"name":"Haus","lat":null,"long":null,"dec":37,"az":-68,"wp":6660},
 "solar_forecast/planes/1/state": {"last_sync":0,"last_check":0,"next_check":0,"place":null},
 "solar_forecast/planes/1/forecast": {"first_date":0,"resolution":1,"forecast":[]},
 "solar_forecast/planes/2/config": {"enable":false,"name":"","lat":null,"long":null,"dec":0,"az":0,"wp":0},
 "solar_forecast/planes/2/state": {"last_sync":0,"last_check":0,"next_check":0,"place":null},
 "solar_forecast/planes/2/forecast": {"first_date":0,"resolution":1,"forecast":[]},
 "solar_forecast/planes/3/config": {"enable":false,"name":"","lat":null,"long":null,"dec":0,"az":0,"wp":0},
 "solar_forecast/planes/3/state": {"last_sync":0,"last_check":0,"next_check":0,"place":null},
 "solar_forecast/planes/3/forecast": {"first_date":0,"resolution":1,"forecast":[]},
 "solar_forecast/planes/4/config": {"enable":false,"name":"","lat":null,"long":null,"dec":0,"az":0,"wp":0},
 "solar_forecast/planes/4/state": {"last_sync":0,"last_check":0,"next_check":0,"place":null},
 "solar_forecast/planes/4/forecast": {"first_date":0,"resolution":1,"forecast":[]},
 "solar_forecast/planes/5/config": {"enable":false,"name":"","lat":null,"long":null,"dec":0,"az":0,"wp":0},
 "solar_forecast/planes/5/state": {"last_sync":0,"last_check":0,"next_check":0,"place":null},
 "solar_forecast/planes/5/forecast": {"first_date":0,"resolution":1,"forecast":[]},
Deklination, Azimuth und Leistung habe ich für zwei Flächen hinterlegt und auch seit ca. 1 Jahr nicht geändert, also seltsam, wenn da jetzt plötzlich was fehlen sollte. Im Debug-Log oben fehlen Längen- und Breitengrad (null), die aber hinerlegt sind. Aber das ist vielleicht aus Gründen der Anonymisierung?
Ich habe die Flächen auch mal gelöscht und (identisch) neu angelegt, aber das macht keinen Unterschied.
Habe ich eventuell noch was übersehen?
Danke und Gruß, Jochen
warp3-2dop-Debug-Report-2026-06-08T20-32-54-273.txt
Scheint ein allgemeines Problem zu sein. Ich habe die Firmware noch nicht aktualisiert und den identischen Fehler.
Vielen Dank, ja, kann bestätigen, dass es wieder tut!
Das ist genau der Grund.
