October 26, 2026 at 09:16 AMOct 26, 2026 Just received my WARP4, and tried the ISO15188 using a Mercedes GLC400e 2023, German version, bought in GermanyWhen the car is already plugged in and i switch the iSO option "get soc from vehicle" the car goes briefly in to alarm and recovers.When the car is later disconnected and reconnected the alarm is persistent, but not blocking the charge. The alarm does not clear until I unplugged the cable.I used the "Faster fallback to normal charging for vehicles without ISO 15118" but that does not seem to do anything.I have not rebooted the WARP after setting that option.Debug log attached. The 34% SOC is incorrect, the car is at 98% now. That 34% may well be from the first action where it recovered. Thanks in advance,Johan warp4-e88s-EVSE-charge-protocol-2026-10-26T09-41-36-171.txt
October 26, 2026 at 09:56 AMOct 26, 2026 In the log it looks like you turned the ISO 15118 off while the EV was connected, it then tried to talk to us, then you turned it on while in the middle of talking to us.We are not handling this well in the firmware, i think i can see why it read the SoC but did not increase it with the charging. I will improve this in the firmware for future versions, so there is no "race condition" any more.Just to be completely sure that there is nothing stuck, please Reboot the box once when no EV is connected (System -> Settings -> Reboot).Does the SoC still get stuck then next time you connect the EV?
October 26, 2026 at 10:09 AMOct 26, 2026 Author I guess the log took some of my previous trials.This is set iso15188 - read soc. Save. No other settings active.Rebooted, started log, plugged car in. warp4-e88s-EVSE-charge-protocol-2026-10-26T11-06-00-512.txt
November 4, 2026 at 07:16 PMNov 4, 2026 Author Not sure if it was supposed to be fixed in the latest firmware. My car still goes into charging error. Several blinks at the charging port of the car, and then a solid red. can only be cleared by disconnecting the cable.Might be that sending the FAULT to the car puts it in this state. Not a high priority at the moment since it only delivers the soc. And as long as the mb-api works soc is delivered by MB servers.
November 4, 2026 at 08:08 PMNov 4, 2026 Oh, i overlooked your charge protocol from two weeks ago, sorry for that. In the protocol it looks like the EV does not actually receive a charge release after ISO 15118-2 communication. The ISO 15118-2 communication itself looks good.I think the charging is blocked with a automation rule? Can you try this again with a configuration where the charge can start immediately? I think the problem might be the missing "welcome charge".
November 5, 2026 at 08:22 AMNov 5, 2026 Author It was blocked, dynamic charging calendar did not allow charging.I only charge when we have low tariff, so i plug the cable in when i come home and the tariff calendar (dynamic tariff) combined with an automation rule blocks charging until low tariff at 22:00. That is a 3ct difference here. I cannot avoid that block (except by getting out of my chair and walk over to the car and plug it in after 22:00). And there may be other blocks that have the same effect. Thanks for the clarification.
November 5, 2026 at 08:31 AMNov 5, 2026 I understand, the problem is that some EVs stop responding when they don't get a charge more or less immediately after plug in. So for example for pv excess charging, if you plug in in the middle of the night, we will do a "welcome charge" and charge for 5 minutes directly after plugin (with 6A) and then stop charging. Then when there is pv excess available a few ours later the EV will respond.If we would not do the welcome charge, the EV would not respond at all a few hours later. AFAIK this is at least true for all MEB platform EVs (Volkswagen, Skoda, etc).But if it works with your dynamic tariffs without reading the SoC (and the EV starts charging etc) with you current configuration, i think i would just leave it as is.
November 5, 2026 at 08:55 AMNov 5, 2026 Author I also have to deal with the Belgian tariffs. With the Belgian tariff structure i'm punished for exceeding the consumption limit. It works like a ratchet, so every charge could push the ratchet up by a notch if i'm already near my limit. So just blindly consuming power could increase the ratchet. Depending on what else is use in the household.To give a simple example, if i would allow by accident the full 11kW for 15 minutes now, i would have an extra bill of 4 euro for this year and 27 Euro next year. November ratchet goes up to 11kW and the averaging algorithm makes sure that those 11kw keep hunting me until Oct 28. For the moment i'll switch the ISO off. Apparently the Merc also supports DIN, but the warp favours ISO. And I have no clue whether it will solve anything.Thanks again for your help.
