Geschrieben October 16, 2013 at 09:4316. Okt 2013 Hi, Could you add a larger mounting plate to your shop? Preferable one that is at least 4 times larger then the current largest one. I can always saw a bit off when its to big. The current plates arent big enough to fit a master brick and a single io16 bricklet. Also, I would like to mount a master brick and several dual relay bricklets on 1 plate. Hope you can make this happen. Kind regards, Geert Schuring.
Geschrieben October 16, 2013 at 11:2816. Okt 2013 Hello Geert, it is possible to create larger plates by screw multiple mounting plates together. For this reason "Mounting Plate Connectors" are included. I hope that is an option for you. Bastian
