Tinkerforge Weather-station python script
Recently published instructions in a PC mag. pointed to http://tinyurl.com/mxw8omx. This download was to employ a completed script, to run the TF weatherstation i.e download and dump data to Drop Box. Sounded very useful indeed. Problem is the script will not run successfully in Gene the recommended compiler for this exercise.
Situation is: RPi "B" Raspibien, Gene running, file (downloaded unzipped as described above) First few lines of script read:
#!/usr/bin/env python
import pygame, csv,os
from pygame.locals import *
from datetime import datetime
import pytz
import upload
from Today import *
Result: Traceback (blah blah blah) Import error: No module named pytz.
program exited blah blah.
As one would have reasonable confidence that this script was tested before publication, one is somewhat startled by this result???
Any ideas?
Ah, this script is from a PC magazine. This information was missing in your German post.
As stated in the other thread, you're just missing the pytz module. On Debian/Ubuntu you can install it like this:
sudo apt-get install python-tz
Thank you photron. This was indeed the solution. I also received a reply from Raspibian who suggested: "easy_install --upgrade pytz"
