Geschrieben May 7, 2014 at 18:407. Mai 2014 Required: * two Sound Intensity bricklets, dangling some 50cm above where your heads are normally positioned in bed. * [optional] Wifi module to pipe the collected data to your PC in another room * some trivial software (below) continuously sampling the stereo bricklets, and dumping the measured values to files. I chose to dump the samples as 32-bit floats so that I can import the "nightly dumps" into Audacity using its "File > Import > Raw Data" feature. My setup produces 2 raw files, one for the "left" and "right" bed positions. Audacity quickly proves that my girlfriend was right in claiming I snore quite loudly. package com.softwarepearls.apps.hardware.tinkerforge.health.snoring; import static com.softwarepearls.lego.time.TimeAndDateKit.*; import com.softwarepearls.lego.audio.enums.StereoPosition; import com.softwarepearls.lego.filesystem.files.FileKit; import com.softwarepearls.lego.hardware.tinkerforge.enums.BrickletType; import com.softwarepearls.lego.hardware.tinkerforge.interfaces.input.SoundIntensity; import com.softwarepearls.lego.hardware.tinkerforge.stack.BrickletDescriptor; import com.softwarepearls.lego.hardware.tinkerforge.stack.TinkerForgeStack; import com.softwarepearls.lego.java.system.SystemProperties; import com.softwarepearls.lego.time.Frequency; import com.softwarepearls.lego.time.TimeAndDateKit; import com.tinkerforge.TinkerforgeException; import java.io.*; import java.util.Arrays; import java.util.List; /** * Bare-bones two-person "sleep noise" recorder (meant to record snoring). For * every night, produces two mono sound files holding the noise volume (not true * sound!) recorded between 20:00 and 09:00. * <P> * Find out who snores the loudest, and when (apnea diagnoser?). */ public final class SleepRecorder implements Runnable { private static final int RECORD_START_HOUR = 20; private static final int RECORD_STOP_HOUR = 9; private final static Frequency SAMPLING_FREQUENCY = Frequency.EVERY_10_MS; // the following constants are specific to my personal setup. Modify to suit // yours. private final static String STACK_IP_ADDRESS = "192.168.0.114"; private final static String DUMP_FOLDER = "Documents/Audacity/SleepRecordings"; private final static String RIGHT_SENSOR_UID = "mkt"; private final static String LEFT_SENSOR_UID = "mmV"; private static final List<BrickletDescriptor> EXPECTED_BRICKLETS = Arrays.asList( // new BrickletDescriptor(BrickletType.BRICKLET_SOUND_INTENSITY, "mkt"),// new BrickletDescriptor(BrickletType.BRICKLET_SOUND_INTENSITY, "mmV")// ); private DataOutputStream rightOut; private DataOutputStream leftOut; private void go() throws TinkerforgeException, IOException { Runtime.getRuntime().addShutdownHook(new Thread(this)); final TinkerForgeStack tinkerForgeStack = TinkerForgeStack.initializeTinkerForgeStack(EXPECTED_BRICKLETS, STACK_IP_ADDRESS); final SoundIntensity rightSoundIntensity = (SoundIntensity) tinkerForgeStack.getBricklet(RIGHT_SENSOR_UID); final SoundIntensity leftSoundIntensity = (SoundIntensity) tinkerForgeStack.getBricklet(LEFT_SENSOR_UID); boolean recording = false; while (true) { if (recording) { recordSounds(rightSoundIntensity, leftSoundIntensity); recording = !waitForEnd(); if (!recording) { closeFiles(); } SAMPLING_FREQUENCY.delay(); } else { recording = waitForStart(); if (recording) { initFiles(); continue; } Frequency.EVERY_10_SECOND.delay(); } } } private void recordSounds(final SoundIntensity rightSoundIntensity, final SoundIntensity leftSoundIntensity) throws TinkerforgeException, IOException { final int rightIntensity = rightSoundIntensity.getIntensity(); final int leftIntensity = leftSoundIntensity.getIntensity(); writeToAudioFile(rightIntensity, StereoPosition.RIGHT); writeToAudioFile(leftIntensity, StereoPosition.LEFT); } private void initFiles() throws IOException { System.out.println("Initializing recordings for today " + currentDayOfMonth() + " " + currentMonth()); rightOut = initRecordingFile(StereoPosition.RIGHT); leftOut = initRecordingFile(StereoPosition.LEFT); } private void closeFiles() throws IOException { System.out.println("Closing recordings."); rightOut.close(); leftOut.close(); rightOut = leftOut = null; } private DataOutputStream initRecordingFile(final StereoPosition stereoPosition) throws IOException { final File userHome = new File(SystemProperties.getUserHome()); final File dumpRootDirectory = new File(userHome, DUMP_FOLDER); final File yearDirectory = new File(dumpRootDirectory, "" + currentYear()); final String monthDirName = String.format("%02d_%s", currentMonthNumber() + 1, currentMonth()); final File monthDirectory = new File(yearDirectory, monthDirName); FileKit.ensurePathExists(monthDirectory.getAbsolutePath()); final String filename = String.format("%02d_%s_%s.raw", currentDayOfMonth(), currentDayName().substring(0, 3), stereoPosition); final File noiseFile = new File(monthDirectory, filename); System.out.println("Opened OK: " + noiseFile); final FileOutputStream fos = new FileOutputStream(noiseFile); final BufferedOutputStream bos = new BufferedOutputStream(fos); final DataOutputStream dos = new DataOutputStream(bos); return dos; } private void writeToAudioFile(final int intensity, final StereoPosition position) throws IOException { DataOutputStream out = rightOut; if (position == StereoPosition.LEFT) { out = leftOut; } final float floatIntensity = ((float) intensity) / 4096; out.writeFloat(floatIntensity); } private boolean waitForStart() { // return true; return TimeAndDateKit.currentHour() == RECORD_START_HOUR; } private boolean waitForEnd() { return TimeAndDateKit.currentHour() == RECORD_STOP_HOUR; } public static void main(final String[] args) throws TinkerforgeException, IOException { new SleepRecorder().go(); } @Override public void run() { try { closeFiles(); } catch (final IOException e) { e.printStackTrace(); } } }
Geschrieben May 8, 2014 at 20:018. Mai 2014 Autor Now my girlfriend thinks she may be sensitive to electromagnetic radiation, so in the interest of domestic peace, I removed my (Wifi-based) setup :'( So now I need an EM radiation sensor.. hmmm... where could I find one of those?
