perl and Remote Switch Bricklet
HI,
I got a mater bricket and a Remote Switch Bricklet to control Intertechno ITL-210 Dimmer (flush-mounted) B, from windows everything works fine when using
Brick Viewer
i installed the service on beagle bone black and from the logs i can see that the master brick was detected when connected to the USB.
i tried using perl exemple to turn on and off the lights but with no success :(
i'm not sure if i'm configuring it the right way.
using example_switch_socket.pl
on the constant UID do i put the master bricket or Remote Switch Bricklet ID?
and i'm not 100% sure on the order of switch_socket(XXX, YYY,$rs->SWITCH_TO_ON);
is the XXX the address from Brick Viewer and YYY is the Unit?
when i run ./example_switch_socket.pl
root@beaglebone:~/perl/scripts/bricklet/remote_switch# ./example_switch_socket.pl
Character in 'C' format wrapped in pack at /root/perl/plugin/Tinkerforge/Device.pm line 147.
Press any key to exit...
and the log file
2014-07-25 14:02:47.500698 <I> <other|main_linux.c:399> Brick Daemon 2.1.0 started (daemonized)
2014-07-25 14:02:47.766618 <I> <usb|usb.c:144> Added USB device (bus: 1, device: 2) at index 0: Master Brick [6JLxVA]
2014-07-25 14:03:53.043673 <I> <network|network.c:105> Added new client (S: 16, T: plain, P: 127.0.0.1, A: disabled)
2014-07-25 14:03:56.122124 <I> <network|client.c:242> Client (S: 16, T: plain, P: 127.0.0.1, A: disabled) disconnected by peer
2014-07-25 14:18:29.056831 <I> <usb|usb.c:313> Removing USB device (bus: 1, device: 2) at index 0: Master Brick [6JLxVA]
2014-07-25 14:18:29.662647 <I> <usb|usb.c:144> Added USB device (bus: 1, device: 3) at index 0: Master Brick [6JLxVA]
2014-07-25 14:18:41.221222 <I> <network|network.c:105> Added new client (S: 16, T: plain, P: 127.0.0.1, A: disabled)
2014-07-25 14:18:42.269642 <I> <network|client.c:242> Client (S: 16, T: plain, P: 127.0.0.1, A: disabled) disconnected by peer
2014-07-25 14:19:41.478672 <I> <network|network.c:105> Added new client (S: 16, T: plain, P: 127.0.0.1, A: disabled)
2014-07-25 14:19:42.479255 <I> <network|client.c:242> Client (S: 16, T: plain, P: 127.0.0.1, A: disabled) disconnected by peer
Br,
Vuko
Hallo vukomir,
after installing the brickd on Beagle Bone, can switch the Intertechno via Brickviewer from PC via Network?
The UID is the UID of the Bricklet, in your case of the "Remote Switch Bricklet".
# Switch socket with house code 42 and receiver code 23 on
$rs->switch_socket(42, 23, $rs->SWITCH_TO_ON);
Please use YOUR values from Brickviewer here!
Maybe more helpful information here: Perl - Remote Switch Bricklet
Der Loetkolben
Hi Loetkolben,
Thanks for the replay, i tried  connecting from my PC with Brickviewer  via network but it's not connecting. :(
this is the entry from the log when i tray to connect.
2014-07-29 12:21:48.863000 <I> <network|network.c:105> Added new client (S: 12, T: plain, P: 192.168.0.28, A: disabled)
bellow is the log in debug mode
2014-07-29 12:38:07.985312 <D> <event|event_posix.c:234> Poll returned 1 event source(s) as ready
2014-07-29 12:38:07.985863 <D> <event|event_posix.c:260> Handling generic event source (handle: 10, received events: 1) at index 4
2014-07-29 12:38:07.986327 <D> <network|client.c:412> Creating client from socket (handle: 12)
2014-07-29 12:38:07.986849 <D> <event|event.c:140> Added generic event source (handle: 12, events: 1) at index 6
2014-07-29 12:38:07.987207 <I> <network|network.c:105> Added new client (S: 12, T: plain, P: 192.168.0.28, A: disabled)
2014-07-29 12:38:07.987539 <D> <event|event_posix.c:275> Handled all ready event sources
2014-07-29 12:38:07.987864 <D> <event|event_posix.c:214> Starting to poll on 7 event source(s)
2014-07-29 12:38:07.996902 <D> <event|event_posix.c:234> Poll returned 1 event source(s) as ready
2014-07-29 12:38:07.997352 <D> <event|event_posix.c:260> Handling generic event source (handle: 12, received events: 1) at index 6
2014-07-29 12:38:07.997750 <D> <network|client.c:303> Got request (U: 1, L: 8, F: 254, S: 2, R: 0) from client (S: 12, T: plain, P: 192.168.0.28, A: disabled)
2014-07-29 12:38:07.998117 <D> <hardware|hardware.c:102> No stacks connected, dropping request (U: 1, L: 8, F: 254, S: 2, R: 0)
2014-07-29 12:38:07.998528 <D> <event|event_posix.c:275> Handled all ready event sources
2014-07-29 12:38:07.998862 <D> <event|event_posix.c:214> Starting to poll on 7 event source(s)
2014-07-29 12:38:17.989430 <D> <event|event_posix.c:234> Poll returned 1 event source(s) as ready
2014-07-29 12:38:17.990073 <D> <event|event_posix.c:260> Handling generic event source (handle: 12, received events: 1) at index 6
2014-07-29 12:38:17.990460 <D> <network|client.c:299> Got disconnect probe from client (S: 12, T: plain, P: 192.168.0.28, A: disabled), dropping request
2014-07-29 12:38:17.990928 <D> <event|event_posix.c:275> Handled all ready event sources
2014-07-29 12:38:17.991256 <D> <event|event_posix.c:214> Starting to poll on 7 event source(s)
2014-07-29 12:38:22.991430 <D> <event|event_posix.c:234> Poll returned 1 event source(s) as ready
2014-07-29 12:38:22.991974 <D> <event|event_posix.c:260> Handling generic event source (handle: 12, received events: 1) at index 6
2014-07-29 12:38:22.992356 <D> <network|client.c:299> Got disconnect probe from client (S: 12, T: plain, P: 192.168.0.28, A: disabled), dropping request
2014-07-29 12:38:22.992828 <D> <event|event_posix.c:275> Handled all ready event sources
2014-07-29 12:38:22.993165 <D> <event|event_posix.c:214> Starting to poll on 7 event source(s)
2014-07-29 12:38:27.993656 <D> <event|event_posix.c:234> Poll returned 1 event source(s) as ready
2014-07-29 12:38:27.994199 <D> <event|event_posix.c:260> Handling generic event source (handle: 12, received events: 1) at index 6
2014-07-29 12:38:27.994735 <D> <network|client.c:299> Got disconnect probe from client (S: 12, T: plain, P: 192.168.0.28, A: disabled), dropping request
2014-07-29 12:38:27.995110 <D> <event|event_posix.c:275> Handled all ready event sources
According to brickd you don't have any Bricks connected to USB.
There was a problem with the USB host on original Beagle Bone, Bricks connected to it didn't work properly due to some USB problem. Maybe the
Beagle Bone Black still has this problem, I don't know.
Things you can test:
- Does it work if you connect the Brick directly to your PC instead of the Beagle Bone?
- Do you have an USB hub at hand to connect between the Beagle Bone and the Brick?
I reinstalled the os(debian) on the BBB and now i can connect with the Brick Viewer over the network and i can switch on and off ITL-210 Dimmer
only it's not working with perl.
in the Viewer i set the address to 1234 and the unit to 1 with this configuration it works, but if i set the same values in the perl script i get
Character in 'C' format wrapped in pack at /root/perl/lib/Tinkerforge/Device.pm line 147.
Br,
Vuko
Ahhh! Sorry, I totally misunderstood your problem.
Everything is working, except from the Perl example.
Okay, now I see what your problem is.
There is a problem in our Perl example for the Remote Switch Bricklet. It is calling the switch_socket() function. This function is there for backward compatibility only. It should actually call the switch_socket_a() function for type A devices.
But you have a type B device (ITL-210). You need to call switch_socket_b() function. Actually you need to call the dim_socket_b() function, because the ITL-210 is a dimmer.
You need to replace this line in the example
with this line
$rs->dim_socket_b(1234, 1, 7);
to set the dimmer value to 7.
HI,
Thanks for the help,
it's working now from perl and C from the BBB :D
