Briklets humidity and motion detector with nagios
hi all,
i need monitor server room with nagios and briklets.
I followed this wiki for temperature
http://www.tinkerunity.org/wiki/index.php/EN/Projects/IT_Infrastructure_Monitoring_-_Nagios_Plugin
and I followed base code
http://www.tinkerforge.com/en/doc/Software/Bricklets/MotionDetector_Bricklet_Python.html#motion-detector-bricklet-python-api
for check motion detector and
http://www.tinkerforge.com/en/doc/Software/Bricklets/Humidity_Bricklet_Python.html#humidity-bricklet-python-api
all work fine.
I need to integrate motion sensors and humidity in nagios.
Can anyone give me some guidance?
I can find a wiki for this?
regards
thanks for replay,
i tried this script, but show always "motion detected"
/usr/lib/nagios/plugins/check_tf_temp_ext.py -H localhost -u sKh -t motion_detector
motion detected
Ah, there was a bug in the script. It said "motion detected" if actually not motion was detected. It said "no motion detected" if actually motion was detected.
I've fixed this now.
There is a blue LED on the Motion Detector Bricklet that is on if motion is detected and is off if no motion is detected. You should now see that the script output matches the LED state.
yes
if self.connected_type == TYPE_MOTION_DETECTOR:
            if val == 1:
was the problem.
Now work fine, thanks
Correct the output of the script doesn't follow the format pnp4nagios expects.
The data pnp4nagios expects is all there, you just have to modify the print statements in the script to output them in the format pnp4nagios expects.
you give me some suggestions for how to do?
regards
There are several print statements in the code like this one:
print "CRITICAL : %s too high %s %s" % (self.name, val, self.unit)
According to the link pnp4nagios expects
<whatever> | <label>=<value>;[<warn>];[<crit>];[<min>];[<max>]
to be printed. The script currently only prints the <whatever> part.
You can extend the print statements like this to add the part pnp4nagios is looking for:
print "CRITICAL : %s too high %s %s" % (self.name, val, self.unit) + " | " + self.name + "=" + str(val)
