Geschrieben December 26, 2015 at 11:1026. Dez 2015 Ok this question might be very ignorant, but how do you setup multiple masterbricks in the openhab? My house will have 7 separate master bricks (one per room to control the light switches, blinds and provide temp readout) all of them with Eternet POE extensions so they will have separate IP's how do I setup them in the openhab.cfg? What is the suntax for the second masterbrick? first is defined as: tinkerforge:hosts=172.16.2.156 And the second?
Geschrieben December 26, 2015 at 22:0626. Dez 2015 Hi xsherlock, just add your brickd/master brick configurations space separated to the tinkerforge:hosts line: tinkerforge:hosts=127.0.0.1:4224 192.168.1.50 192.168.1.104 This is an example copied from the openHAB wiki docs: https://github.com/openhab/openhab/wiki/Tinkerforge-Binding#example-configurations Regards, Theo
Geschrieben December 27, 2015 at 04:4127. Dez 2015 Autor Ok that is brutally simple. But can you tell me how openhab knows that particular "XYZ" bricklet is behind given IP address. Does it use multicast to communicate or it is using pooling on the setup phase to determine that? Maciej
Geschrieben January 8, 2016 at 20:028. Jan 2016 The binding opens an ipconnection to each configured brickd address and has a virtual device model for the bookkeeping.
Geschrieben January 13, 2016 at 12:5913. Jan 2016 Autor OK, that is smart. I still however have a bit of the problem setting up a second IO16, First is configured as in the examples tinkerforge:io16.uid=w1j tinkerforge:io16.type=bricklet_io16 tinkerforge:io16.debouncePeriod=100 tinkerforge:io16ina0.uid=w1j tinkerforge:io16ina0.subid=ina0 tinkerforge:io16ina0.type=iosensor How do I add the second one? Like that? tinkerforge:io16_second.uid=xxx tinkerforge:io16_second.type=bricklet_io16 tinkerforge:io16_second.debouncePeriod=100 tinkerforge:io16ina0_second.uid=xxx tinkerforge:io16ina0_second.subid=ina0 tinkerforge:io16ina0_second.type=iosensor
