ipcon_connect returns -4 (◾E_NO_CONNECT)
I am creating a C++/MFC program to run the stepper motor.  I have included "ws2_32.lib" and "advapi32.lib" in the project properties (linker additional dependencies).
I am using the following defines:
#define HOST "localhost"
#define PORT 4223
#define UID "5W5jBJ" // Obtained from running brick viewer
I am using the following code, taken from the example code:
// Create IP connection
IPConnection ipcon;
ipcon_create(&ipcon);
// Create device object
Stepper stepper;
stepper_create(&stepper, UID, &ipcon);
// Connect to brickd
if (ipcon_connect(&ipcon, HOST, PORT) < 0)
  //returns -4
Everything compiles fine, but I can't connect.  I have loaded the brickd drivers for the stepper motor, and I can connect and run the stepper motor using brick viewer.
Any clues as to what I may be doing wrong?  Thanks.
The modified version of ip_connection.c I gave you can resolve "localhost" to its IPv6 address, but brickd doesn't bind to an IPv6 address by default.
To make ip_connection.c resolve "localhost" to its IPv4 address you need to replace AF_UNSPEC with AF_INET in your ip_connection.c.
Can I ask a follow up question?  Your suggestion worked and we are now able to run the stepper motor.  However, when execution of the following test block is finished, I have memory leaks.  Obviously, this block doesn't do anything except connect and release, but I wanted to isolate the memory leak problem:
IPConnection ipcon;
Stepper stepper;
stepper_disable(&stepper);
ipcon_destroy(&ipcon);
My output windows shows:
Detected memory leaks!
Dumping objects ->
{586} normal block at 0x006E50C0, 4248 bytes long.
Data: <    5  6n    > 01 00 00 00 20 35 F6 C0 E0 36 6E 00 02 00 00 CD
Object dump complete.
Thank you for any advice.
The code does more than connect and release. You're calling stepper_disable which disables the stepper motor driver. You should call stepper_destroy instead. The memory leak comes from not calling stepper_destroy.
It seems that these destroy calls are missing in all our C/C++ examples. I'm going to fix that now.
Fantastic, thanks very much.  I thought the disable instruction was not enough, and I even looked for a destroy command but somehow missed it.  My fault.  All's well now and we are off and running.  At least until the next question!
