Geschrieben September 12, 2019 at 09:5012. Sep 2019 Hi, I've spent the last months extending our binding generator to be able to generate openHAB bindings. The 23rd beta version can be found here. Installation: The bindings require an openHAB 2.5.0 Milestone/Snapshot installation. To install the bindings, just copy the two JARs into the addons directory of your installation. openHAB will then load the bindings. Afterwards you can add a Brick Daemon over the inbox. Configuration: Attached devices are automagically put into the inbox after adding the Brick Daemon instance. Devices and channels can be configured: Channels typically allow changing the update rate. Some Bricklet's configuration can show/hide channels, for example the IO-4/16's pin configuration will dynamically create input or output channels. Sometimes the PaperUI needs to be refreshed by pressing F5 to show new channels. Only configuration that is stored in a Bricklet's RAM is supported. Persistant configuration has to be set externally (e.g. by using Brick Viewer), because openHAB will often reconfigure devices, for example on startup or when reconnected to a Brick Daemon. Writing persistant configuration would then take too many write-cycles. Further documentation: Can be found here: https://www.tinkerforge.com/en/doc/Software/API_Bindings_openHAB.html#api-bindings-openhab Actions in rules: There are actions to be used in rules available for all devices. To use actions of a device in a rule, first the actions have to be loaded with: var devActions = getActions("tinkerforge", "tinkerforge:[devicetype]:[Device UID]") Then they can be used with devActions.[actionname]([parameters]). The following example shows how to show a GUI on an LCD 128x64 Bricklet with the UID "HQ6": rule "startrule" when System started then var lcdActions = getActions("tinkerforge", "tinkerforge:brickletlcd128x64:HQ6") lcdActions.brickletLCD128x64ClearDisplay() lcdActions.brickletLCD128x64RemoveAllGUI(); lcdActions.brickletLCD128x64SetGUIButton(0, 0, 0, 60, 20, "button"); lcdActions.brickletLCD128x64SetGUISlider(0, 0, 30, 60, 0, 50); lcdActions.brickletLCD128x64SetGUIGraphConfiguration(0, 1, 62, 0, 60, 52, "X", "Y"); lcdActions.brickletLCD128x64SetGUIGraphData(0, newArrayList(0, 10, 20, 40, 20, 15)); lcdActions.brickletLCD128x64SetGUITabConfiguration(3, false); lcdActions.brickletLCD128x64SetGUITabText(0, "Tab A"); lcdActions.brickletLCD128x64SetGUITabText(1, "Tab B"); end Functions that expect arrays as parameters can also be called with lists, as shown in the call of setGUIGraphData in the example. Results are returned as a Map<String, Object>, that can be used as follows: rule "otherrule" when Item Enx_Button changed to OFF then val lcdActions = getActions("tinkerforge", "tinkerforge:brickletlcd128x64:HQ6") pixels = lcdActions.brickletLCD128x64ReadPixels(0, 0, 127, 63).get("pixels") val inverted = pixels.map[p | !p] lcdActions.brickletLCD128x64WritePixels(0, 0, 127, 63, inverted) end This rule is triggered if the Item Enx_Button changes to OFF (i.e. if the corresponding RGB LED Button is released). It will then read the pixels currently shown on the LCD Bricklet, invert them and draw the inverted pixels back on the LCD. Nearly the complete API of devices can be used as actions. Operations that invalidate the state of channels will refresh them automatically. Not supported are operations, that would write EEPROM or Flash Storage, to avoid unneccesary write-cycles. Display Bricklets: Text can be set as follows: [line],[position],[text]. Further ',' after the first two are handled as part of the text. In the text you can use the display's character set directly with \x[two hex digits]. Unicode characters are furthermore mapped to the display character set, as is done in the code examples, see f.e. here: https://www.tinkerforge.com/en/doc/Software/Bricklets/LCD20x4_Bricklet_Java.html#unicode As an example 1,2,Hello, opεnH\xE0B! will print Hallo, opεnHαB! stating at line 1, column 2 on an LCD 20x4. The small epsilon was mapped from Unicode into the LCD character set, 0xE0 (224) is the small alpha. PaperUI truncates whitespace at the start and end of commands. So to clear (parts of) a line, you can not use f.e. 1,2,[spaces]. Instead you can use the empty character like this 1,2,\xFE\xFE\xFE to delete three characters at Line 1, Column 2. Missing features: Channels accept one CommandType only. For example the LED of a RGB LED Button Bricklet can only be set using an HSBType, not the others that openHAB expects support for (e.g. if only the brightness is changed, an PercentType is sent). Known Bugs: Display Bricklets show '-' as text (NULL if clicked), if no text was already set using the UI. PaperUI does not show descriptions of channel(types) and configuration parameter groups. These are listed in the doc subfolder per device. Unknown Bugs: If you find another bug, please attach the openHAB Log. This can be found in the userdata/logs folder of your openHAB installataion. If the bug is reproducable, you can try to increase the log level with log:set TRACE org.openhab.binding.tinkerforge in the karaf console. Maybe this will show more useful information. log:exception-display can help too. If there are errors shown in the PaperUI, they can be investigated using the web developer tools of your browser. Run the network monitor, reload the page and take a look at the responses of requests with status code 500. log:exception-display (in the karaf console) could be useful here too.
