brickd install error in tx2(Ubuntu 16.04)
Hello everyone
    when I uesd the command "sudo dpkg -i brickd-2.4.0_amd64.deb" to install brickd,I meet the below error:
(Reading database ... 225415 files and directories currently installed.)
Preparing to unpack brickd-2.4.0_amd64.deb ...
Removed symlink /etc/systemd/system/multi-user.target.wants/brickd.service.
Unpacking brickd:amd64 (2.4.0) over (2.4.0) ...
dpkg: dependency problems prevent configuration of brickd:amd64:
brickd:amd64 depends on libc6.
brickd:amd64 depends on libusb-1.0-0.
brickd:amd64 depends on libudev1 | libudev0.
dpkg: error processing package brickd:amd64 (--install):
dependency problems - leaving unconfigured
Processing triggers for man-db (2.7.5-1) ...
Errors were encountered while processing:
brickd:amd64
but I have already used " sudo apt-get install build-essential pkg-config libusb-1.0-0-dev libudev-dev pm-utils"  install the depends package.
Can you help me? Thanks
hello thanks for your reply but I have already try this befor.When I install the "armhf" version,its give me this error:
  dpkg: error processing archive brickd_linux_latest_armhf.deb (--install):
package architecture (armhf) does not match system (arm64)
I used source code to fix this problem.Thanks
That's strange, that dpkg doesn't complain like this when you tried to install the amd64 version.
Anyway, we currently don't provide a precompiled brickd for arm64. Therefore, compiling from source is the best option you currently have for arm64.
  • 1 year later...
