Geschrieben September 25, 2019 at 08:1825. Sep 2019 Hello everyone when I uesd the command "sudo dpkg -i brickd-2.4.0_amd64.deb" to install brickd,I meet the below error: (Reading database ... 225415 files and directories currently installed.) Preparing to unpack brickd-2.4.0_amd64.deb ... Removed symlink /etc/systemd/system/multi-user.target.wants/brickd.service. Unpacking brickd:amd64 (2.4.0) over (2.4.0) ... dpkg: dependency problems prevent configuration of brickd:amd64: brickd:amd64 depends on libc6. brickd:amd64 depends on libusb-1.0-0. brickd:amd64 depends on libudev1 | libudev0. dpkg: error processing package brickd:amd64 (--install): dependency problems - leaving unconfigured Processing triggers for man-db (2.7.5-1) ... Errors were encountered while processing: brickd:amd64 but I have already used " sudo apt-get install build-essential pkg-config libusb-1.0-0-dev libudev-dev pm-utils" install the depends package. Can you help me? Thanks
Geschrieben September 25, 2019 at 08:5325. Sep 2019 The NVIDIA Jetson TX2 has an ARM CPU, but you're trying to install the amd64 version of brickd. Try the armhf version instead.
Geschrieben September 26, 2019 at 01:5826. Sep 2019 Autor hello thanks for your reply but I have already try this befor.When I install the "armhf" version,its give me this error: dpkg: error processing archive brickd_linux_latest_armhf.deb (--install): package architecture (armhf) does not match system (arm64) Errors were encountered while processing: brickd_linux_latest_armhf.deb
Geschrieben September 26, 2019 at 03:5326. Sep 2019 Autor I used source code to fix this problem.Thanks
Geschrieben September 26, 2019 at 08:1626. Sep 2019 That's strange, that dpkg doesn't complain like this when you tried to install the amd64 version. Anyway, we currently don't provide a precompiled brickd for arm64. Therefore, compiling from source is the best option you currently have for arm64.
Geschrieben December 1, 2020 at 14:471. Dez 2020 The Brick Daemon Debian package is now also available for arm64 architecture.
