Geschrieben August 21, 2012 at 22:0621. Aug 2012 I'm thinking about doing some light dimming with this velleman kit: http://www.vellemanusa.com/products/view/?country=us&lang=enu&id=521945 The thing is, it requires 0-10v input to control the light. Do you have any suggestions on how to get that kind of output with a Tinkerforge device? I was thinking about the DC brick, but as far as i know it is not possible to control voltage, only velocity. Any suggestions is welcome!
Geschrieben August 22, 2012 at 07:4322. Aug 2012 Hi Anton, typically these interfaces can be controlled with a adjustable resistor. For example you can attach a 10k Ohm potentiometer to it and control the light. Currently there exist no product for this application.
