Geschrieben September 1, 2012 at 12:571. Sep 2012 Hello, I must receive some information over the RF (433MHz), i have the sender and the receiver. I have a master brick and a 16 I/O. is there a way to connect the RF Module to make my brick and then use a Java app to manage the incoming information? Thanks a lot.
Geschrieben September 1, 2012 at 16:471. Sep 2012 Hi Danoscar, we currently don't offer a 433Mhz receiver momentarily, so the question is if there exist a suitable receiver for your purpose. This was one of the first hits at google: http://www.futurlec.com/Radio-433MHZ.shtml The problem will be, that you have to implement the protocol which these modules are talking. So its no easy task. If you try to do this have the maximum API calls per second in mind.
